Cannot give you any real ideas or shoot you for that matter.
You’ll just have to spend some time browsing all the galleries and see what you like the most.
How big will you be going with this army? because that will affect how much effort it will need to complete all the bases. If its a real complicated type of base, you’ll then have to justify or accept the amount of time it will take to get what you want.
Grimbold Blackhammer:
There are plenty of awesome and cheap companies out there that make bases. I’d browse some of the different stores to see if you can find one you like, browse the ‘Showcase’ forum here, check out coolminiornot.com for ideas, and do searches for images of chaos dwarfs. Somewhere you’ll find something that appeals to you and how much work you want to put into your models. Much like your paint scheme, how you base your models depends a lot on your own skill, how much time and or money you want to spend on it, and what you like. I use cork for my Dark Elves and I don’t regret it at all but one of the locals at my LGS saw my Forgeworld models and said I had to get awesome bases for them. So I did (they aren’t expensive!) and I definitely did not have buyers remorse about it.
So here’s a question that only you can answer - are you just putting this army together as quickly as possible so you can play or are you planning on putting in some real effort? I’m so impressed with the bases I’ve seen, both mine but several others as well, that if you aren’t just throwing this army together, I’d definitely go with purchased resin bases.
Chaosftw:
You'll just have to spend some time browsing all the galleries and see what you like the most.
How big will you be going with this army? because that will affect how much effort it will need to complete all the bases. If its a real complicated type of base, you'll then have to justify or accept the amount of time it will take to get what you want.
Abecedar
There are plenty of awesome and cheap companies out there that make bases. I'd browse some of the different stores to see if you can find one you like, browse the 'Showcase' forum here, check out coolminiornot.com for ideas, and do searches for images of chaos dwarfs. Somewhere you'll find something that appeals to you and how much work you want to put into your models. Much like your paint scheme, how you base your models depends a lot on your own skill, how much time and or money you want to spend on it, and what you like. I use cork for my Dark Elves and I don't regret it at all but one of the locals at my LGS saw my Forgeworld models and said I *had* to get awesome bases for them. So I did (they aren't expensive!) and I definitely did not have buyers remorse about it.
So here's a question that only you can answer - are you just putting this army together as quickly as possible so you can play or are you planning on putting in some real effort? I'm so impressed with the bases I've seen, both mine but several others as well, that if you aren't just throwing this army together, I'd definitely go with purchased resin bases.
Thanks for the replies.
@Abecedar: I will be collecting these little monsters for ever so this army will be fairly large.
@Grim: I am the only guy at my local gaming store that plays the dwarfs so I will for sure be putting in as much time as it takes.
Any suggestions on basing sites? I'll start hunting around and see what I can find.
Nice work on the stands. Looks like it was a lot of work and patience to get that many put together all at once.
They remind me of Skinks bases…are they based on his tutorial?
Anyways, again, nice work :hat off
Seems like you put in a lot of time and work on those bases, but I think they look very good so far. LF to seeing some paint on those, Great job so far!!
That’s quite some work! They look good now and will look even better with minis and paint on them.
