Gar Shadowfame:
Besides normal limitation, i cant have more than 6 power and dispell dice, every boundspell counts as 1 power dice, 2 basic dices are also part of this limitation.
this is ment to be a competitive rooster
1200 Pts - Chaos Dwarfs Army
Unit Name ## Mv WS BS St To Wo In At Ld Sv WSv Cp Dp US Cost
Earthshaker 1 6 4 3 4 5 3 1 3 4 5+ 3 100
Daemon Engine; Range 48", Stone Thrower, troops under 5"
template 1/2Mv and cannot shoot, machines shoot on 4+
Crew 3 3 4 3 3 4 1 2 1 9 5+ 1 [0]
Heavy Armour
Death Rocket 1 6 4 3 4 5 3 1 3 4 5+ 3 90
As smaller Cannon, instead of bounce place 5" template, S3
Armour Piercing
Heavy Armour
Armour Piercing
Heavy Armour
Hobgoblin
Spear Chukka 1 7 3 35
48", St6 D3 Wo, -1S/Rank, No armour save; Single unit = Bolt
Thrower & 2 Crew
Crew 2 4 3 3 3 3 1 2 1 6 1 [0]
Hobgoblin
Thrower & 2 Crew
Annihilators 17 3 4 3 3 4 1 2 1 9 5+ 1 204
Blunderbuss; Range 12"; Roll to-hit for each model in target
unit (no modifiers except S&S); Hits at St3 +1/rank (max St5);
Heavy Armour
Warriors 12 3 4 3 3/5 4 1 2 1 9 5+ 1 180
Great Weapon; +2S (+1 if mounted). Strikes last in HtH unless
charging; Heavy Armour; Standard; +1CR
Banner of Daemonic Bound Spell, Power Level 3: Unseen Lurker spell from the Lore of [30]
Tides Shadow; May only be cast on the unit with the banner
Slaver 1 3 4 3 3/5 4 1 2 2 9 5+ 1 [30]
Daemonsmith 1 3 5 4 4 4 2 2 2 9 3+ 1 1 162
May act as crew for Daemonic Engine; Hellcannon joined may
re-roll failed Rampage rolls; Chaos Armour; Shield
Chalice of Fire May roll a D3 at the start of either players magic phase. Remove [30]
that many dice from both player’s magic pools. One use only.
Hexacon of Hashut Instead of making a Dispel roll, bearer may roll 6D6 & if the [20]
total equals or exceeds enemy’s casting roll, spell is
prevented; May not be used if spell cast with IF; One use only
Holocaust Cloak +1 to cast (or +1 to power level of bound spells) [45]
Rubric of Daemonic
Whispers Enemies w/in 12" must reveal magic items
