[Archive] 1500 CD first list,comments appreciated
Vradek:
My first army list with the wicked stunties. Any suggestions are gladly welcome:
Chaos dwarf hero:armour of gazrakh-sword of might 112
Chaos dwarf sorcerer: 2 dispel scrolls 150
20 warriors:full command-hand weapon/shield 210
12 warriors with blunderbuss 144
10 hobgoblin wolfriders:musician-bow 150
30 hobgoblins:full command-shield/light armour 154
24 sneaky gits:champion-musician 140
3 hobgoblin bolt throwers 90
earthshaker 110
1500 pts 4PD 3DD
Cheers
minty:
downgrade the sorcerer to level 1, saving you 35 points, then pump those into the BBs, and your lord isn’t fast anyway, so swap the sword of might for a great weapon, and get even more BBs, giving you 16, and your lord will be stronger.
51la5:
Same as Minty but also drop the musicians on the warriors and the gits that gives you 30 points you can use for another bolt thrower.
Xander:
I might try to increase the CD units to 25 to allow for some casualties and still retain your 3 Ranks. I might drop the LA/Sheilds on the Hobbos, and possibly the command too, if necessary, to get the points for your CDs. Try to increase the number of BBs to 14 (+ Sorcerer for 15 [5x3]) or 17 (+ Sorcerer for 18
Vradek:
Ok,I will update the list as soon as possible.
Thanks a lot for the advice:)!!!
Well I think they could be a good flanking unit and I like them because I find them very good in the general Chaos Dwarf background theme.
Cheers
