[Archive] 2400 all comers list
wizuriel:
I’m mainly just posting this so I know where to find it later, but some comments/criticism would be appreciated. Pretty much trying to make an all comers list (main people I know that play warhammer play the boring dwarves, tomb kings, wood elves and lizard men). This is what I’m playing around with
Lord (380)
Sorcerer Prophet: Lvl 4, Talisman of Preservation, crown of command = 380
Heroes (437)
Infernal Castellan: BSB, shield, Mask of the furnace = 197
Daemonsmith Sorcerer: chalice = 145 [hell cannon]
Daemonsmith Sorcerer: 95
MLP:
A few things I would consider with that list:
Your two IG units are stubborn but only 20 models each may be a bit low. By the time they get to combat they could be down to half strength from magic and artilary.
You could cut a daemon smith out and just use one for both. Just hope you don’t need two rerolls in one turn. It just seems a bit much spending 240 points just for rerolls and a little magic.
Against wood elves you should win flaming>flammable.
Not sure against the other armies tbh but a pretty solid list i think. Maybe drop daemon smith and shields on BC for more IG.
Grimbold Blackhammer:
Hellcannons are monsters, not war machines. No rerolls for them =(
I’d ditch a sorcerer and either turn him into either a Tar’ruk (allowing you to ditch one bull centaur) or more Infernal Guard/Hobbos. Three wizards at 2400 points is a lot.
Not sure you’ll need the Crown of Command on your Sorcerer-Prophet. Might make room for a Dispel Scroll in there instead.
wizuriel:
Good catch with the hellcannon :frowning:
Lord (380)
Sorcerer Prophet: Lvl 4 (lore of Hashut), Talisman of Preservation, crown of command = 380
Heroes (342)
Daemonsmith Sorcerer: lvl 1 (fire), chalice = 145
Core (754)
23 infernal guard: GW, FC = 377
Special (380)
4 bullcentaurs: GW + standard + banner of swiftness + Champ = 235
1 magma cannon = 145
Rare (530)
K’daai Destroyer = 325
Hellcannon = 205
total = 2386 / 2400
MLP:
I think 4 more IG per unit will make a good difference to their survivability. It’s another turn of spell or war machine fire. The Deathshrieker is also a good option.
20 hob gobs is probably too small in 2500 and the BCs don’t need two more to do their job.
FAQ just came out and the Deamonsmith now DOES effect a Hellcannon. Woohoo!
