Looks ok, except for the fireglaives. I think you might be too dependant on getting the countercharge to make them effective. I would swap them for a unit of 20 hobbos with bows, and also add bows to your other hobbos. You are unlikely to have 10 IG with fireglaives left to negate ranks if you do countercharge, whereas you probably will have 2 ranks left with at least one unit of hobbos.
I’d put the charmed shield on your daemonsmith rather than ptolos, which won’t give you any protection against cannons etc, and still give you a 3+ save.
Add 3 extra IG to get a full unit of 30 (with characters), then you can run them in ranks of 5 or 6.
You need a ward save on your BSB. Mask of the furnace is a good one as it gives you an extra +1 armour save as well. Then just have a normal shield. Give the enchanted shield to your sorcerer, so both main characters have a 2+/4++ save.
I’ve seen mask of EEE! on khans recomended as he might just scare chaff away rather than having to fight anything.
I’ve not tried death on the sorcerer, but should be good. Lore of hashut is good if you get ashstorm and flames of azgorh. The others are ok (breath of hatred especially if you cast it while all your units are close at the start of the game - destroyer and hellcannon with hatred? Oh yes).
And don’t forget the daemonsmith allows a reroll for the hellcannon as well as the normal warmachines!
So my 1st game VS high elves went pretty damn well last night. I used my above list (with dispel scroll)
He had:
Lvl4 (4+ward) shadow
Lvl 2 (ring of fury) high
2 blocks of spears
2 x 12 archers
2 eagles
2 bolt throwers
Block of Swordmasters (banner of sorcery)
2 x 5 dragon princes.
It ended up 20 �?" 0 to be (2335 vs 620) as he managed to kill my K�?Tdaai (well I failed the T test) turn 6.
Things that went well:
1: Hellcannon rerolls are epic (17 spearmen in 1 shot)
2: Deathshriker was good for more spearmen
3: hobgoblin archers were ace. With enchanted blades they knocked out half the Swordmasters (before 1 unit got munched by them), an eagle and some archers.
4: Khan cannon on wolf held up a unit of dragon princes for 2 turns before dieing…to horses�?�but gave me enough time to hell cannon them.
5: Infernal guard with HW/S and AP banner are solid.
6: Bull Centaurs can take a kick in.
Bad things:
1: Misplacement by my own mistake meant the K�?TDaai got tar pitted by a unit of dragon princes, until 3 turns later when my centaurs could bail them out.
2: death magic range and some high casting is a bit meh
3: lack of high WS can mean it tough to get better than 4+ in combat.
At the moment I am thinking of making my level 4 fire
Thats what we thought! totally shocked when they pulled it off. 12 (remaining unit) also took out the last standing dragon prince with stand and shoot. I was well chuffed
Good job! Hobbos can be a susprisingly good unit, you don’t expect much from them but sometimes they deliver.
Presumably he didn’t get PoS, or you dispelled it each time? Having the other shadow spells won’t do much good if his units are decimated by warmachines by the time he gets to you.
How did the destroyer do, and did you have complaints about it?
He chose mind razr over PoS, the tube, as he wanted to mind razor up his dragon princes to smash the K’Daai.
He failed to cast twice and I scrolled it once.
He realised his mistake in not taking pit of shades by turn 4, when he had not much left to hurt me with.
The K’Daai was stuck for 4 round of combat with the dragon princes. He failed lots of hits which meant he didnt have many dice to roll 1’s with (bloody dragon armour)
He did soak up alot of attention and magic though (withing to reduce toughness etc) and if it wasnt for me rolling a 6 on turn 6 for his tougnness test and them taking 3 wounds, he would have lived.
Against other armies I think he will do alot better. Dragon armour has a way of doing annoying things to flaming attacks.
Love the list, except a few upgrades and items, it’s pretty much the same I’m building at the moment.
I’ve been considering fielding both my lord and smith with the lore of fire, but I see a lot of people favouring metal on their secondary caster. Might I ask how the metal-smith performed?
In the 1 game I have played with him he did alright. He got enchanted blades of albian which made the hobgoblins with bows very amusing vs HE swordmasters. Ruby rung did ok to.
Reason Im taking a lvl 1 metal as in the last tournament I went to (using HE) my level 1 metal took out:
1 steamtank
1 Iron Blaster
3 Mournvil Cat Cav
6 Chaos Knights
1 Warshrine
8 Chosen
1 Hyrdra (well to 1 wound then ring got him)
Not bad really!
That isnt including his kills from Ring of Fury
I see alot more knights around nowadays, plus things with “Really good saves” which, for his points, can cause untold panic in the enemy
1 steamtank
1 Iron Blaster
3 Mournvil Cat Cav
6 Chaos Knights
1 Warshrine
8 Chosen
Not bad really!
I see alot more knights around nowadays, plus things with "Really good saves" which, for his points, can cause untold panic in the enemy
wamphyri101
Quite impressive!
I guess most CD will have limited ability in negating armour, and mostly in CC with our monsters.
Cheers wamphyri101, you've convinced me to try out Metal :hat off
So after a few games now (got humped by WoC last night, but lost due to shittest dice ever VS best dice ever) I have changed a few things:
1: Lord went. He was ok, but too many point on 1 character which didn�?Tt return enough points in support or deaths. He has been replaced with a level 2 with fire and feedback scroll for funsies. I know they don�?Tt have shields, but will be placed so cannot be shot at and can still see for magic.
2: GW given to Bsb, as he had no damage output. He still gets a 3+/4++ but at least gets 3 str 6 attacks (with banners AP)
3: Bumped up the infernal guard to have the option of hording them depending on opponent.
Looks good. I am considering running two hero level casters instead of the usual lord and hero combo. The thing I’m really worried about is that everybody else takes a level 4, so I need a level 4 just to break even on magic defence.
You could always drop the feedback scroll to give them magic shields.
Two magma cannons should be particularly nasty. Presumably your two daemonsmiths are babysitting the warmachines between them? Otherwise they’d be fairly squashed together.
I disagree with your reasoning for not taking the lord level prophet.
You’ve instead taken a level 1 and 2 caster which cost nearly the same points as a lord level caster (upwards of 325pts).
Those two casters will not cause nearly as much damage in the magic phase as a prophet would. On top of that the prophet provides the army with a sturdy LD 10 general able to take a 2+ save followed by a 4+ ward save. He helps the guard unit/bsb out and makes the unit a solid anvil.
The 2 smiths may help the cannons out a bit, but they are not worth it in my opinion over the prophet.
The most ideal set up for this type of list would be a prophet supported by the bsb, level 1 and a khan. To fit those characters in you would have to look at dropping a war machine (which is what you had in your first list on the top of the page).
