[Archive] [AoS] Updated Legion of Azgorh rules from GW
With the new General’s Handbook out tomorrow, GW has updated all of their Age of Sigmar FAQs, and also redone a whole load of their compendiums (compendia?), including the FW ones. Full article is here, but the relevant bits for us lot are linked below:
Legion of Azgorh
FW Pitched Battle profiles
Someone more familiar with the rules than me will have to spot all the changes. For one thing, everything’s alphabetical now, and I spotted the wording on spiteshields being tidied up.
Heavygear:
Most importantly infernal guard with shields are always battleline. So you can pull units from other factions as allied AND use your evil dwarves. You also get to use allied detachments up to a certain points limit and retain LoA status no matter what battleline you are using. So hell cannon, great taurus and lammasu are all useable. Fireglaives and now bull centaurs are battleline if Legion of Azgorh. There is a restriction on allies if match play. No skaven. Maybe the engineers are too competative. Lol.
Heavygear:
The infernal guard battle line change also means you can use goblins without affecting LoA status.
Heavygear
Actually...
The updated compendiums now remove the faction keywords from the legacy units. So a Hellcannon, for instance, is no longer Slaves to Darkness, which means you can't ally it with LoA.
That said, since Ironsworn are now straight Battleline, you can just run a Chaos allegiance army and chuck in what you like. Pure Grand Alliance forces should get lots of new stuff in the Handbook, so you won't miss out.
gsteelwraith:
The question I have is how do we use our slaves in this new edition of the rules? The Warscroll calculators still allows one to use the Grots and Grot Wolf Raiders, but otherwise I haven’t seen anything in print suggesting we can use them. I’ve just started adding them into my army on a trial basis, and I’d hate to think I’ve thrown money away on units I’m not even allowed to field.
You use them the same way you used to: by bringing the models to the game with your army.
You can’t use them in matched play (can’t mix Grand Alliances) and, even if you can, you won’t get any allegiance abilities. But this is exactly the same as it used to be: the Substitute Warscrolls section never overrode those limitations.
If anyone’s interested, I was perusing the Age of Sigmar app on my phone and saw that the LoA units had ‘full’ warscrolls with backgrounds etc… They look a bit nicer and match the format of the redone legacy ones, so I screenshotted them and put them into a single PDF. I’ve also thrown in the Hellcannon, Great Taurus, Lammasu, Gitboss, Grots, Wolf Riders and Spear Chukka warscrolls, as well as the relevant matched play profiles (only the ones available for free though - you’ll need the General’s Handbook for the Grots, Wolf Riders and Spear Chukka, sorry!).
Download here.
Note: these are screenshots, so each page is an image file, which means you can’t search the text I’m afraid.
Barth:
Great job Tommy :hat off thank you veryl much
Maybe put it on  TGA legion of azgorh thread too �Y~S
Timothy Archer:
nice work , thanks !!
Skink:
Well done Thommy!!! You´ve always been our Scribe Castellan in chief!
Wildist:
A good use for hobgoblins is using them as a “counts as” allies unit. As some cannon fodder brayherds is still fluffy and probably useful rulewise. Now the sky is the limit as you could literally convert some black orcs and use them as blood warriors or warriors of chaos, hobgoblins as ungors, convert some tzaangors into hashutgors… whatever you please. Allies are a good tool for us heavy converters because it legitimates our fluffy miniatures. Even “hobgrot” raiders could be user either as mounted daemonettes or centigors. It is really up to you.
Carcearion:
On the subject of counts as, I came pretty late to the Chaos Dwarf party. What was the difference between Hobgoblins and Goblins back in the day? What where Hobgoblins better at then Goblins?
They had an extra pip of WS and Ld. Basically they were the midpoint between Goblins and Humans.
Carcearion:
Wow Goblins are two pips lower than humans on WS and Ld?
Hmm�?� I don�?Tt know that Kings of War has the granularity for a good choice on that one for which way to go. I think Goblins will probably feel most correct (I feel like a Hob is probably reasonably more like a Gobbo then a Human).
No, they were worse than humans in a different way.
Goblins were 4 2 2 3 3 1 2 1 5
Hobgoblins were 4 3 3 3 3 1 2 1 6
Humans were 4 3 3 3 3 3 1 3 1 7
In AoS, Grots (goblins) are the usual substitute for hobgoblins because, as in KoW, there isn’t as much granularity as in WHFB. But basically anything human-sized but kind of cowardly works. Ungors, for example.
Carcearion:
Hmm… ill have to explore the ungor option.
Thank you! :hat off
Roark:
Our steam trains got good. They fixed our Bulls. They fixed our BSB. Pretty amazing and unexpected tbh.
Timothy Archer:
im looking at the warscroll right now , and Drazoath does not have any command ability , is it normal ? can’t remember about the old warscroll .
Roark:
I don’t think he ever had one.
moogoodoo:
I use my hob goblins as maruaders and black orcs as warriors. No one minds and it adds to our army
