[Archive] Base Size **This message was automatically appended because it was too short.**(1)
CopperPot:
Just out of intrest before I start converting my own Lammasu the base is what 50x50 on the GW website, so thats rather small compared to the base size of Forgeworld big Bulls (can someone tell me the size please).
So when it comes to fluff is the Lammasu smaller than the Great and Bale Taurus, I would like to convert my lammasu using the Stonehorn but looks massive for a 50x50 base.
Any advice would be great :cheers
Yes, the Lammasu is smaller. It goes on a 50x50 mm base. The Great Taurus is on the same, whereas the Bale Taurus is on a 50x100 mm (chariot) base.
CopperPot:
Thanks for the reply
so the stonehorn is rather impractical for gaming then.
To represent a Lammasu, yes.
The Besieger:
The base size for the Bale Taurus is 60mm x 100mm :slight_smile:
The_Bear_in_the_Hat:
I’m converting a Lammasu from the Stonehorn (see here http://www.chaos-dwarfs.com/forum/showthread.php?tid=11003) and it will fit onto a 50x50 base - I’ve just put it onto one now to test it. It looks a bit daft on a base that small, but it does fit and it doesn’t fall over.
I’ll put a picture up tomorrow showing it on the smaller base.
CopperPot:
The base size for the Bale Taurus is 60mm x 100mm :)
horlely
Screaming Bell size then Thanks.
CopperPot:
I'm converting a Lammasu from the Stonehorn (see here http://www.chaos-dwarfs.com/forum/showthread.php?tid=11003) and it will fit onto a 50x50 base - I've just put it onto one now to test it. It looks a bit daft on a base that small, but it does fit and it doesn't fall over.
I'll put a picture up tomorrow showing it on the smaller base.
The_Bear_in_the_Hat
Yeah just checked that out very nice, i cant imagine that on a 50x50 base.
khedyarl:
I’m converting a Lamassu out of the Bale taurus mini, Bear. The thing to keep in mind with the Lamassu, is that there is absolutely no benefit (in fact, only drawbacks) for having a large base on a miniature like that - which lends itself well to players not complaining about it. If you were to put a Burning Body model on an enormous base, then people would probably start to have issues. Ultimately, I wouldn’t worry about it. You could always magnetise the base, and if somebody really does have a problem, swap the base out.
I wonder - would the Stonehorn fit on a 50x100?
Yes, Khedyarl. The Stonehorn does fit on a 50x100 base.
khedyarl:
If it fits on the 50x100 without looking silly, you may want to toss it on there if you’re worried. The frontage is identical, and the only benefit{?} you get is that it’s easier to flank you. :stuck_out_tongue:
That’s the models on alternative bases.
CopperPot:
Wow so it fits but yeah just as I thought it doesn’t look right to me, I know to many bellends who would complain about not being able to get into base contacts.
Yeah, i doesn’t look great on such a small base - though the Taurus works on a bas that size, which surprised me.
Shame you know so many bellends - I think the conversion will end up working fairly well.
CopperPot:
I think I might try the chaos manticore model but I don’t like the hands with abit of greenstuff work I might be able to pull it of.
