Dervish Helldance:
I am thinking about converting a couple of sorcerers (thinking about making one of each kind from Tommy H’s book; sorcerer lord, pyrophant, daemonsmith), but I am not completely sure what dwarf models fit best to use as basis for them, considering that the majority wear armour and neither sorcerers nor pyrophants use armour. So what I’d like to ask is: what models have you found useful for sorcerer foundations?
Pyrophants are here and here. The background was actually written with these models in mind.
For Daemonsmiths, the Warhammer Forge pack is also pretty much perfect.
As above - I also like the original fire sorcerer from Dwarf crewman idea. Quite a simply conversion and most wear little or no armour. A little greenstuff on the cannonball and it’s a fireball. First example of this can be seen here.
Dervish Helldance:
Yes, I have seen all those, not bad at all. Just thought if anyone had some other idea of a base model, but I guess I will most likely convert a crewman or baggronor’s pyrophant a bit. Thanks anyway (but if someone have another idea not mentioned, please tell!).
Discoking:
I quite like the look this of this guy as a Daemonsmith…
