[Archive] blue highlights on a black beard?
Timothy Archer:
Hello
I’m seeking for help to paint a beard
I would like to know if someone could explain me the way
To make those cool dark blue highlights on a black beards
It seems to me that the old hat cd were painted this way
Is it just dark blue + white or is there a special trick
Thanks to all
T
Depends.
If you want a rich, lustrous colour, you mix blue with your black basecoat, then add more blue for each subsequent highlight. You can do a final highlight with a touch of white to make it pop.
If you want a slightly more realistic colour, you do the same for a layer or two, then start adding white instead of blue. That gives you a result like the beard of the guy in my avatar.
Timothy Archer:
Thanks I think I go for the first choice.
Danke schön �Y’O
You could also try using Necron Abyss ( or whatever it is called now) as the base coat and then black wash / shading
Dînadan:
Iirc, a method I used on some of my CDs was to drybrush with a grey and then give it a blue wash.
Timothy Archer:
Dînadan
Can be pretty interesting too. Thanks to all
