Greetings followers of Hashut. I have a question about the hellcannon: can it pivot before fireing? I understand both sides of the argument:
1) it is a monster so it can’t pivot before fireing because any movement negates the shot.
And the counter argument is:
2) the cannon is fired as per the rules for a stone thrower that in turn follows the rules for warmachines while it fires so it gets a free pivot as per the warmachine rules.
I’ve always used the second argument. How do you all play it?
It can't move before firing. Been FAQed. It's primarily a monster.
So setup is crucial. Puy the hellcannon on the table last, in a corner and in a 45° angle - to be sure to fire.
Bloodbeard
Yeah i feel that but the faq supports both trains of thought:
as per the faq:
Q: Does pivoting on the spot count as movement for the purposes of
units, other than war machines, with the Move or Fire rule?(p73)
A: Yes.
But also it says:
Page 109 �?" Shooting with War Machines.
Change �?oUnless specified otherwise, all war machine
weapons�?��?� to �?oUnless specified otherwise, all weapons in this
section (and all other weapons mounted on war machines)�?��?�
The second faq section refers to the stonethrower portion of the hellcannon so it takes it's rules from the warmachine section when it fires the stonethrower because the stonethrower is a warmachine.
Am i just looking at the faq in the wrong way? Does it really back up both schools of thought?
Think I read somewhere in a dark tome of forbidden knowledge (or one of countless forums I search for an answer), that it’s only the firing part. A watmachine can’t fire if it moves. And a monsters counts as moving when it pivots.
My interpretation is that you are ok to pivot in the shooting phase then shoot. The hellcannon shoots like a stonethrower (a warmachine). The ability to take a pivot in the shooting phase before shooting is part of the rules for “shooting a warmachine”. If it shoots like a warmachine, then it must follow the rules for “shooting a warmachine”, which includes the free pivot in the shooting phase.
