I have seen a lot of guys in here converting alot of figures to pretty much the same thing. My question is, when a guy have made/converted a model. Why dosen’t he make a cast and then cast another 40 guys, with 3 or 4 poses, so he is free of making each and every single one of them?
I have did some casting of figures… not all of the casting come out just right. there a lot of work to it and the silicone you use molds can add up for what you get …But if you do it as fun and learning project it better …but as i found out it cost as much sometime to get the casting stuff its as cheep to buy figures on e bay. ME i rather make them out of green stuff… to me it faster
no the molds ware out ! faster if there more detail you also have to have the mixture of resin just right if not there grewy or air bubbles get trapped and mostly it in the face i find out.
don’t get me wrong it fun but it not a perfect way to make that many troops
Cost of silcone to make mold is 19.00 dollars you may get 2 molds out of it
resin 2 part mix is 15.00 dollars may get 12 figures out of them
so that 34.00 dollars you can get 10 gw figures for 28.00 new
don’t get me wrong its fun but messy
just giving you ideas Sweetie of some price it cost
But a lot of people use (or used) casting efficiently! Look at Ishkur’s or Bas’s blog and maybe drop them a PM. They are both fairly active and I’m sure they will give you some help… Otherwise check this out.
In my experience casting is really hit and miss and takes forever to do a decent sized unit. Perhaps I’m just impatient, but personally I’d save up and try and find a contract caster these days.
Yes you can cast an entire army/unit, but 1: its a lot of work still, 2: it needs a lot of extra work to clean up all the models. and 3: it will take forever. (5 you will ruin you clothes burn your fingers if you are not careful).
Oh Its a lot of fun, yes its is! So do it because of that reason. (and dont even think about weird shapes and complex models)
i have found that 3D printers are a lot easier to make detailed figures but then again it is not cheaper because the cost of the printer and the materials
