[Archive] CD Reroll Token
Loidrial:
Almost all of you know the site COMIXININOS where you can buy models from bloodbowl.
http://www.ebay.it/itm/Fantasy-Football-SET-2-CHAOS-DWARF-REROLL-TURN-MARKER-for-Blood-Bowl-Meiko-/231469710404?&_trksid=p2056016.m2516.l5255
This here is a set of 2 token head of a chaos dwarf, anyone of you knows the size?
I will like to use it for something, but I dont have a proper idea, it will look cool on a wall for some scenery, but I dont have any atm
Nice one! I can’t help with its size. Apart from wall decoration, it could also work as a banner or adornment on the flank of some warmachine. As for fresque, one or two of those faces could look particularly good at a burning altar.
Dînadan:
Loidrial
1" square roughly - says in the item description if you scroll down ;)
Loidrial:
Loidrial
Dînadan
So what will be like the orc base? the one of 25mm? It could be than more interesting than expected (probably i was going to buy there the meiko bullcentaur hero, lready bought a lot from those spansh ppl in the past)
Dînadan:
Item description says 25mm x 25mm, so yes, the size of an Orc base; sorry, forgot you continentals only have the metric system (for future reference, 1"=2.54cm :wink: ).
Loidrial:
Item description says 25mm x 25mm, so yes, the size of an Orc base; sorry, forgot you continentals only have the metric system (for future reference, 1"=2.54cm ;) ).
Dînadan
Because the metric one is the Only acceptable ;P
When I will buy it I will post it here
