If I roll a “hit and misfire” the rocket shoots of 4d6, but do I still roll on the misfire chart?
If I roll a "hit and misfire" the rocket shoots of 4d6, but do I still roll on the misfire chart?Nope.
tjub
Revlid:
No. The Rocket spinning off is the Misfire! result.
Alan the evil:
No. The Rocket spinning off is the Misfire! result.it's not totally correct:
That’s what he meant, Alan. In the case of rolling both a hit and a misfire, the “misfire result”, rather than rolling on the chart, is the 4D6" thing.
Tarrakk Blackhand:
That’s when the rocket bounces all over the battle field…spinning out of control until it hits something, right?
No, it just goes 4D6" in the direction indicated by the little arrow on the “Hit” symbol. In 4th/5th Edition it used to potentially bounce around a few times if you rolled right (or wrong, depending on your point of view…) but now it’s just one “bounce”.
Alan the evil:
In the case of rolling both a hit and a misfire, the "misfire result", rather than rolling on the chart, is the 4D6" thing.Aaaaaaaaaaaaaahhhhhh...... OK!
It’s okay - I think it was just a translation issue! I’m not clever enough to speak any other languages, but I’ve studied enough about English and its origins to know what a silly language it is. Any foreigner who can figure out how to speak or read it well enough to actually use it regularly has my eternal admiration.
Tarrakk Blackhand:
I guess I must still be thinking of the 4th ed rules for rockets. Seems a little more “kool” back then in some ways…esp the rocket bouncing all over the place, however, I can see why they took that rule away as it could potentially take a week for a rocket to explode.
No, it’s just that they had one paragraph to explain the rules in Ravening Hordes, so it got simplified. If you have two pages per army list, some rules have to go.
Border Reiver:
I guess I must still be thinking of the 4th ed rules for rockets. Seems a little more "kool" back then in some ways....esp the rocket bouncing all over the place, however, I can see why they took that rule away as it could potentially take a week for a rocket to explode.It definitely could. I once had a rocket ricochet 5 times around the board. It finally landed on the launcher and blew up - 5 minutes later my opponent and I stopped laughing long enough to remove the casualties...
Tarrakk Blackhand
