If I place the counter for the Demolition Rocket on the centre of the Screaming Bell/Furnace, and I roll a hit since the whole model is hit as per Deathshrieker rules, do both the mount & the rider get the Strength 8 hit or do I roll which part of the model is hit (rider or mount)?
The problem is that if you are using Demolition Rockets, there is no ‘under the hole’ and ‘regular’. There is only one type of shot. I would think it would work like a cannonball, hitting everything at strength 8.
@Spartacus: That was my impression but I wanted the feedback from you guys. The Cannon has one Strength value, so both the rider & the mount are hit with the same Strength. However if the Dreadquake/Hellcannon were to shoot & hit the model, you’d have to randomise who gets the Strength 10 & the other gets the Strength 5.
@Spartacus: That was my impression but I wanted the feedback from you guys. The Cannon has one Strength value, so both the rider & the mount are hit with the same Strength. However if the Dreadquake/Hellcannon were to shoot & hit the model, you'd have to randomise who gets the Strength 10 & the other gets the Strength 5.
KramDratta
Now you only have one kind of strength, so they both got to hit
The problem is that if you are using Demolition Rockets, there is no 'under the hole' and 'regular'. There is only one type of shot. I would think it would work like a cannonball, hitting everything at strength 8.
Spartacus
I would say the opposite. The Demolition Rocket, is not a template, its a single hit, so I would randomise who gets the hit, same as you would if you hit it with an arrow or a bolt thrower or something.
When the Death Shrieker uses the �?~Demolition Rocket�?T ie the 1 inch marker, is that considered a template rules-wise? Ex if it touches 2 models do both of them get hit or does the controlling player get to choose. Same if it hits a rider on a monster mount, since it has one strength value do both get hit (as a cannonball)?
and this is their reply:
Sent: 14 December 2011 12:37
Subject: RE: Deathshrieker query
Hi there.
The �?~Demolition Rocket�?T does not have a 1 inch marker, it just hits one model and if it is not clear as to which model the shot hits, randomize between the models. For a Monster mounted Character the shot hits both elements of the model as with a cannon ball.
Thanks
Tris Buckroyd
So there you have it. It can be considered as our Strength 8 cannon, that can hit only one model.
Does the Demolition Rocket position/model count as a template ? Ex if a it hits a building do D6 models get hit (like a cannon/stone thrower)? Or if I place it on a character in a unit, does he/she get the Look Out Sir! roll as per cannon/stone thrower?
Cheers
And their reply:
Sent: 15 December 2011 15:51
Hi there.
It will count as a template in that regard and Characters will get look out sir rolls.
All in all, I’m liking the Deathshrieker. It can kill Hydras/Hellpits with one shot, removing the regeneration whilst at the same time can take care of big blocks with the 5" inch template. The Infernal Engineer re-roll improves the reliability.
Folks unless I am missing something the demolition charge is not flaming only the larger template is so while the charges can take out a hellpit or abom they get a regen save
