Gar Shadowfame:
Does anyone managed to get into an ETC team and will play with CD?
Gar Shadowfame:
Uzkul Werit:
I know one of the Irish team is using them.
Bolg:
Jup, I’ll be there and I’ll bring CD’s (: (:
Last year there was only one CD player, I hope there will be 2+ this year.
Bolg:
Does anyone managed to get into an ETC team and will play with CD?Anyone else?
Gar Shadowfame
KramDratta:
I wanted to field Chaos Dwarfs, but unfortunately I’ve been vetoed
Bolg:
I wanted to field Chaos Dwarfs, but unfortunately I've been vetoed :(What? Why? What happend?? Were you there last year. (what county are you representing and what are you bringing now?)
KramDratta
Bolg:
Its next weekend. are there more people to say hello to?
Bolg:
So the first draft of the Rules for 2011 are up:
ETC Rules pack, 1.draft:Seems like CD’s and DoW arent allowed (yet) but I do plan to go. rules as the are now are a bit iffy but its only the first draft so we’ll see what happens.
At ETC we will be using a LOS system. AR.com will present two alterative systems with this rules pack and asks the captains to playtest both before making a recommendation. This can be found in the following thread viewtopic.php?f=18&t=78142
Rules changes:
- Steadfast is removed if a unit is disrupted.
- Units with at least one full rank cause Disruption.
- Characters will get “look out sir” versus the following spells that automatically kill models or automatically remove an entire regiment: Dwellers Below, Final Transmutation, Dreaded 13th, Infernal Gateway 11-12 effect. Normal requirements for lookout sir apply.
General Restrictions:
2400 Points.
No Special or Named Characters.
Armys can be selected from any of the currently published GW Army books.
A maximum of 4 identical core choices may be taken (regardless of equipment and other upgrades).
A maximum of 5 warmachines may be taken per army
Unit sizes of are limited as follows:
- Non-infantry units (including monstrous infantry): Maximum 12 models/unit
- Infantry costing 5 points or less: Maximum 40 models/unit
- Infantry costing 6-9 points: Maximum 30 models/unit
- Infantry costing 10 points or more: Maximum 24 models/unit
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- You may have units/abilities that actually would generate more than 2 extra dice, but any excess dice are lost
- Some magic items/abilities count as generating dice toward this limit.
- �?oCount as�?� items/abilities may never exceed a cumulative 2PD/DD per phase. This means that if you take the power scroll, you may not take any other items that �?ocount as adding PD/DD�?�
Item restrictions:
- Power Scroll counts as generating 2 PD and 2 DD each magic phase
- Each Loremaster ability counts as generating 1 PD each magic phase
- Items that auto-dispel a spell counts as generating 1 DD each magic phase
- Folding Fortress is not allowed
Army Specific Restrictions:
Beastmen: No Restrictions
Bretts: Trebuchet is a 0-1 choice
Dark Elves: Hydra is a 0-1 choice
Dwarves: Anvil of doom counts as warmachine; Grudge Throwers are a 0-2 choice; Max +4 dispel dice instead of +2
DOC: Flamers are a 0-1 choice. Siren Song may only be taken once
Empire: Steam Tank counts as warmachine; Tank, Rocket battery and Engineers are a 0-1 choice
High Elves: Book of Hoeth counts as generating +2PD and +2 DD; Shard and Crystal as +1DD/phase
Lizards: Salamanders are a 0-1 Choice; Terradons, Chameleon Skinks and Stegadons (any kind) are 0-2 choices; Beclaming cogitations counts as generating +2DD, Cupped hands as +2PD/phase.
Ogres: No Restrictions
O&G: No Restrictions
Skaven: Hell Pit Abomination is a 0-1 choice; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice
Vampires: Wraiths and Varghulf are 0-1 choices
TK: No restrictions
WE: Wand of Wych Elm counts as generating +1 DD/phase
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as generating +2DD /phase; Tendrils of Tzeench and Conjoined Homonucleus all count as generating +1 PD/Phase.
- Infantry costing 6-9 points: Maximum 30 models/unitAnyone else think this is a bit too small? If this was written for 7th ed it would make more sense.
Fallen246:
I will agree with you.- Infantry costing 6-9 points: Maximum 30 models/unitAnyone else think this is a bit too small? If this was written for 7th ed it would make more sense.
Grimstonefire
Skaven: Hell Pit Abomination is a 0-1 choice; Gutter runners are a 0-2 choice; Engineers are a 0-3 choiceEhm, limit on Jezzails? Doomrocket? Storm Banner?
Vampires: Wraiths and Varghulf are 0-1 choicesSeriously? Well that limits 2 of the best things in the army, one of which is already ludicrously overpriced, leaving VCs with no other decent Rare options and only Grave Guard worth taking as Special. Lame.
I think there should be an upper limit to stop deathstar units, but the limit they set is definitely too small as most things can’t even make a decent Horde.
I would have said this:
- Infantry costing 5 points or less: Maximum 50 models/unit
- Infantry costing 6-9 points: Maximum 50 models/unit
- Infantry costing 10 points or more: Maximum 40 models/unit
Or possibly even
- All infantry: Maximum 40 models/unit
As the lowest level you can get with horde infantry getting one extra rank to allow for missile casualties on the way in.
