[Archive] First ever conversion
War Paint:
Well Xander et al have inspired me to take my first steps and do my first real conversion and sculpting.  Pictures are just quick scans.
This I have decided will be a unit leader.  bits are:
BOSP dwarf warrior (Goes without saying)
Chaos Maruder head minus back half and hair
Chaos Marauder axe arm
Added hair and helmet plate at back and chainmail bib to try and get bit different to others I’ve seen.  Pleased with over sculpt on right arm though and whole of left arm is GS
Skull off skaven banner piece and other beard ornaments from cut down sprue
Comments wanted.
[/align]
catbarf:
The armor is great. I think, however, you should work on the beard- instead of doing lines going the whole way, make a line coming from one side that goes 2/3, then do the same for the other side, alternating. It gives a much better effect.
I also think the bib is a little weird. Cut it so it stays behind the shield and it’ll be fine.
Xander:
Looks awesome! But I think you meant Chaos Warrior not Marauder. :slight_smile:
Nicely done.
Ghrask Dragh:
Looks Awesome War-Paint!
The hair at the in particular is impressive sculpting, The body armour is really well sculpted, I also like the new style ‘bib’ at the front!!
Critisisms would be the shield sleeve looks abit warped? if you look at the extremley well-done armour just below on the ‘skirt’ you can really see the difference, just try to keep the pattern a litle more constant. And if you have a filing tool I would try to make the shield a bit smoother (it will really show up when you paint it otherwise).
For a first conversion this is fantastic! I really like the choice of head and weapon (especially the weapon!!) and really can not wait to see more! :hat off and congratulations on your first converted Chaos Dwarf :cheers
War Paint:
Thanks for all the helpful comments gang
Shield - In 2 minds about this. I wanted a battle worn look. It really depends what I decide to paint on it I think
Shield arm - Yep the armour is not as good agreed, also I think the arm needs to be a bit bigger. I think I rushed this a bit. Got excited and impatient and wanted just to finish by then so I could see the whole thing.
Beard - I will try what catbarf said on next one. I want to be able to do really fancy beards eventually so practice practice!
Weapon arm - Xander your spot on I did mean chaos warrior
Bib - I quite like the chainmail bib. I’m going to keep as is for now. Was going for the look you see on the old swivel gun crew. Next time I will probably do the whole face chainmail like that mini
Hair - Thanks Ghrask - I was really pleased with this and enjoyed doing it and slicing and raising the occaissional strand as it cured.
I think I will tidy it up a bit next, try making the bottom of the scale armour a bit more even and sharp - probably just a new scalpel blade along the bottom.
Ghrask Dragh:
Ah, I didn’t think of the battle-worn look in which case looks good!
Those swivel-gun crewmen are the coolest pre-hat stuff around!!! how good would it be to get army looking like those guys :slight_smile:
War Paint:
Thats the general theory and GW era look I want Ghrask - hopefully I can do it in practice
torn:
definately a chaos chaos dwarf! i think style wise you are definately on target if your trying to go for the early look, i would love to see it painted as im curious if your going to go with the early style red and green colours or if our going to do something completely different.
the use of the face mask is really well done
War Paint:
torn
Still thinking about the colours - Gonna try to get painted asap, but got 200 figure comission to do as well! As well as all my other figures - I'll see if I can squeeze it in bit by bit
Nice work, the classic CW mask is a nice one for elite models - makes them stand out. It’s slightly more difficult to cast though. The one thing I would change is the axe; I think its too big and I play Khorne. Those weapons were oversized on Chaos Warriors, on dwarfs its just pushing it that bit too far
