Narflung:
cool, i love the way you gave done the base, fully textured on the sides as well. Keep it up
Merchant:
Interesting, I’ll be waithing for the rest of them to come
the base is really great.
Cheers :cheers
i like blue and lava bace.
Good combination of colours. I especially like the lava detailing and the base. However, i have a query: When putting these models together, will the textured sides not prove a problem?
furrie:
I havn’t tried it yet, only have one model textured
i was gonna ask the same as HB. Surely it makes things a little tricky
Narflung:
Nah, you shouldn’t have a problem ranking them up if you make your own movement trays. The GW ones will be tight, but on one of my other armies I made my own bases that were just slightly wider than normal.
furrie:
I will first try it with the newest movement trays, the ones you give your own size and if that doesn’t work I will make my own
This_Is_My_Boomstick!!:
the modular movement trays are great, i just made one so i can have a unit of 20 chaos dwarfs and a centaur on it and still have 1 extra space, had to work on cutting the lengths due to me using all the corner sections
the best part about them is the extra 1mm gap all around
furrie:
I have finshed the greens for 10 more blundies, here they are:
now I’m working on a bilt trower, 16 CD with great weapon, the sorcerer lord on lamasu and painting 19 blundies.
i really like the mask on the one to the right. Only real problem is that some of the blundderbusses seem a little floppy. Have you tried using the buckler method?
furrie:
What is the buckler method?
furrie
You use the little shields that come on the Thunderer/Quarreller sprue to make the ends of the blunderbusses. You can then smooth out the barrel with green stuff if you want.
There are some examples here: [[Chaos Dwarf Blunderbuss Conversions]].
furrie:
the problem is, I don’t have that sprue, my thunderers are from the bfsp box.
i totaly love the beards is the last guy in the first row looking up ??
furrie:
he is just looking around, beeing bored
Fridericus_Rex:
Wow. Damn nice BT! I like it very much. How long did it take? The Lammasu you have already postet but it looks great!
furrie:
I think about half an hour. I don’t know the precies time, because I didn’t finshed it in one time, needed to wait till the glue from some parts where dry, so I went on doing others things and I forgot the BT
