[Archive] Help with flaming attacks rules
Rettile:
Hey guys, i have some questions for you:
1- What happens if a unit with flaming attacks hits and wounds single wounded flammable enemies?
2- Same here but with BS shooting
3- Still the same but with template shooting (ie magma cannon)
4- Just to be sure, same questions against multi wounded models
Thanks for your time :hat off
Odatria:
Rettile
Nothing special happens in either case against single wound enemies, they only have one wound to lose so they can't lose two. No additional wound is inflicted on another model or anything like that. From shooting it's the same, and from templates.
When flaming hits a flammable multi wound enemy each wound becomes 2 wounds, or in the case of the magma canon d3 wounds x2, which means you work out how many wounds are done as usual, double it, and then remove that many wounds taking whole models away before moving on through the wound pool. For example, your flaming breath attack hits a unit of treekin covering all 3 models. You hit 3 times so roll to wound 3 times. Let's say you roll 2 wounds, this now becomes 4 wounds. One treekin is removed and another takes the last wound.
The above is right.
The think to remember is this: If flammable the unsaved wounds are doubled - after saves and ward saves. And it only works on miniatures wirh 2+ wounds on their profile.
pedneault:
Multi-wounds to maximum of the W on the profile.
Example : flaming cannon on ogres with ashtorm on it. D3wounds�-2 to a maximum of 3 per wounds.
