If u chose to take 6 BC or 6 Fireborn, how wide do u make them?
3 wide x 2 ranks, or 4 wide first rank x 2 wide second rank?
Btw, anyone tried 9 of any of them in one unit? or is it just a point sink?
I’m not sure why you wouldn’t put them in two ranks of three, since that many is required for a rank bonus, and they can still make all their Attacks because of the Monstrous Support rule. Putting four in the front rank gains you nothing.
I just wondered what people do
If i where to put them wider, it would be to get the extra stomp attacks when i engage a horde.
Yes, I forgot about Stomp. Still, I think most people would go for the rank bonus instead.
JMR:
Yes, there’s the bonus of a stomp, but more importantly I would go 3 wide to make your unit easier to manoeuvre and reduce the amount of return attacks, especially vs. a horde.
Grimbold Blackhammer:
It depends on the unit itself and the enemy I am facing…
- a unit of three centaurs and a centaur hero will be two wide with the hero and champ in the front to minimize casualties
- a unit of more than three centaurs will be three wide
- I consider a unit of K’daii Fireborn’s minimum viable unit size to be 6 models which I generally run only three-wide. Unless they are against a squishy T3 low armour save enemy in which case I’ll go wider to try and get more in base contact at a time.
frogbear:
Monstrous support is only for monstrous infantry so BC do not get it - just in reply to Thommy’s post.
Its a shame because BC could really use the rule.
Otherwise as said above, moving 4 BC wide is extremely annoying - so three wide for myself for them
My Fireborn I take in a frontage of 3, however I do like the idea of a 4 frontage vs T3 opponents. May have to look at combat reforming in future - if my 2nd rank has survived…
Geist:
When it comes to BC, they suck so much offense wise that the only way I can ever see to run them is thusly:
3 wide with shields and musicians in a group of 3.
Purpose:
To hunt down annoying units that normal khans or wolves could not handle. Also to provide support for skull cracker in case it gets stuck into cav.
frogbear:
When it comes to BC, they suck so much offense wise that the only way I can ever see to run them is thusly:I go with GW myself as their strength is less than desirable for the point sink. Whatever they hit, I want them to hurt. They can 'usually' take the offesive hits first if they are attacking the correct unit.
Purpose:
Geist
I didn’t realize until Frogbear pointed it out that Bull Centaurs not in the front rank go from their already unacceptable two attacks per model to just one. So long beautiful models; you’ll never see the light of day again!
frogbear:
Grimbold, I still they they are worth it if only to get the Taur’ruk.
He is pretty much the 2nd Special Character that we never got.
Monstrous Beasts and Cavalry get Monstrous Support too. It was in the very first Rulebook FAQ.
frogbear:
Monstrous Beasts and Cavalry get Monstrous Support too. It was in the very first Rulebook FAQ.I am sure it has been said before but..... Thommy is da man! :hat off
Thommy H
