Swissdictator:
A bit less static grass maybe?
A bit less static grass maybe?Yes, less is more.
Thommy H
At least you might want to trim down the grass, using nail scissors.
definitely less. it looks like caterpillars are surrounding them
You could also add some “stones” respectively some “rubble” imo it would fit quite well!
And like the others just mentioned remove some “grass” and trim it!
Anonymouse:
Or shave it a bit. At least trim it :pA bit less static grass maybe?Yes, less is more.
Thommy H
Admiral
its also spaced out too perfectly and I wouldn’t expect grass patches to grow like that.
Bolg:
If i see this correct. you havent painted the stones on the base, just glued in place.
So give them a drybrush highlight is the least you could do.
But the thing is, there is already a lot of black in the model, so black bases really dulls them down, try a few experimental colors before (or in this case after) you base your entire army.
Maybe try a gray - white highlight and paint the sides of the bases dark gray. (or brown - orange whit brown sides). use leff grass and try a more colorfull grass.
(but this is all just my humble opinion)
ChungEssence:
I think Graveyard Earth would look a lot better than the black for the bases.
Also, dry brush any rocks etc.
