[Archive] Iron Daemon Remixed
There’s been a bit of discussion in a few threads recently about how complicated the Iron Daemon is to use - as a Unique unit with a full page of rules detailing all its exceptions to the usual rules, it can be a bit of a headache to field, with a few people saying it’s not even worth using it because it takes so long to explain to opponents!
Khedyral, Cornixt, myself and a few others discussed some solutions in this thread and we sort of concluded that it would work best as a chariot with a couple of special rules. The issues are less with the rules per se as they are with how they’re explained - if I just wanted to rewrite the whole thing, I’d just point you towards my own Infernal Engine rules. The trick is to resolve the existing rules in a consistent and elegant fashion. For example:
  • How does its special random movement work? You have to declare a charge, but you can also use it just to move faster.
  • It can’t charge or march normally, but this isn’t totally spelled out.
  • The thing about it only Thunderstomping in the second and subsequent rounds of combat is buried in the rules - Baggronor and I both managed to miss it, and we’re really smart.
Now, I’m not saying the unit doesn’t work. I’ve called this a remix because, as far as possible, I’ve made it mechanically identical to how it works in Tamurkhan. Once explained, it’s perfectly functional…it’s just the way you have to wade through a whole page of exceptions to get to that point. 99% of this work is Alan Bligh’s, and I don’t mean any disrespect to him - the unit is his, and the rules are his, I’m just explaining them in a way that I think makes a few things a bit more clear. I think the Iron Daemon is just a victim of the odd story of Tamurkhan’s development, going from a crazy, almost unique addition to a WoC army to a Special choice in a Chaos Dwarf force. You might see three of these things on the table!
This version is very slightly different - the accidental charge thing is gone altogether, replaced wholesale by Random Movement, which already has a charge mechanic. I’ve also taken away the thing about it destroying obstacles and just given it Obstacle Strider. Everything else is just clarification of existing rules. The points costs are unchanged, but I’ve opted not to include the text of the Carriage Hauler rule because a) it’s too long and b) no one uses it anyway, do they?
This should work fine with the LoA, or any other Chaos Dwarf book you may be using.
rabotak:
great stuff, a perfect clean up of the rules.
i know this has been stated a gazillion times before, and I´m fully aware that this probably goes against your own interest, but still:
GW/FW should hire you.
haha, I’ve been working on something similar, I might as well not bother now! That pretty well distills the rules into how they should be without really changing them. I’d swap Thunderstomp for a rule that does exactly the same thing against all types of units, but apart from that it looks like you’ve fixed the problem areas.
Yeah, I considered that - the Steam Tank just does a certain number of hits in the same way, but I think its vulnerability to non-Stompable units is major enough for dropping it to constitute a pretty big change and would thus require a points hike.
rabotak:
NoisyAssassin:
Wow, this is an impressive condensation of the rules. Clear, concise, and makes sense. Bravo.
lukealexandermorton:
Only issue with this PDF is the movement section you state if you use its random movement you put 6 plus 2D6 “. I read it as the iron daemon may activate its 2D6 move but doesn’t add its 6” movement.
Kind Regards
No, you add the 2D6 to its regular movement. Hence, 6+2D6".
