[Archive] Iron Daemon to Skullcracker
The Gib:
I currently have the Iron Daemon model assembled and painted. I would like to run this as both the Iron Daemon and the Skullcracker, but would rather not have to buy both models. Wanted to see if anyone had a good way, or knew of a link that showed a good way to do this. Just a good conversion piece that can be added the ID to make it a Skullcracker. Any help would be great.
Grimbold Blackhammer:
I’m quite sure you’ll be fine just by announcing when you deploy it that it has the Skullcracker upgrade. I don’t think anyone will demand it be modeled.
rpitts2004:
I agree with grimbold, shouldn’t be an issue.
moses:
i never tought about this, but i like your idea.
you could use this part:
http://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat440269a&prodId=prod30013a
fits perfect for a machine thats called skullcracker.
and 11,50 euro is pretty cheap.
moses
The Gib:
I agree, I think that would work perfectly and is inexpensive
If you could pick up some bitz of the blade wheel things from the new daemon chariot that would look pretty awesome as well.
I agree with grimbold, shouldn't be an issue.
rpitts2004
Agree as well
Something big and spikey that you can stick in the front of it would work well enough if you just want the visual appearance.
