[Archive] Iron Demon
Grimbold Blackhammer:
Are folks equipping them with the Skullcracker or sticking with the cannon? Both seem very viable and while I like the cannon option, 300 points for a mobile cannon seems expensive.
Time of Madness:
Neither seem viable to me as the iron daemon can be held up all game by a lone eagle. Not to mention chariots, cav or any other flyers.
Once opponents start to realize this a lot of people are going to stop taking the iron daemon.
Time of Madness
rabotak:
I´m using the cannon-version, and I like it a lot. it´s a good flank holder, warmachine-babysitter, it kills monsters quite easily and can launch attacks on its own.
and the best thing is: if you set your priorities right, you won´t have anything to fear from eagles or fast cav and the likes :wink:
I’m starting to think multiple IDs could work. Say, 2 Skullcrackers and a regular ID. Properly supported by Hobgoblins (to remove enemy steadfast) and a Destroyer (for total overkill) they could do a lot of squashing and would be very difficult for many opponents to kill.
Maybe its a viable build: Prophet on either big flyer, 2-3 IDs, Destroyer and loads of Hobbos. At the very least, it would be unexpected :slight_smile:
khedyarl:
I’ve been running an Iron Daemon, and haven’t experienced the problems Time of madness is running into. Opponents know they need to hit it in the flank with an eagle or light calv, but it’s easier said than done if you’re careful. Run it with a unit of Infernals within an inch and a half of the flank of the Daemon, and it’s invulnerable from that side.
If they’re charging you in the front with calv/Flyers, then stand and shoot them. At that point, you just need to worry about the one flank, and with access to fairly offensive Lores on Daemonsmiths, and Ash Storm on the Prophet, I’ve found taking care of the Daemon to not be a huge task.
bengtb:
I've been running an Iron Daemon, and haven't experienced the problems Time of madness is running into.  Opponents know they need to hit it in the flank with an eagle or light calv, but it's easier said than done if you're careful.  Run it with a unit of Infernals within an inch and a half of the flank of the Daemon, and it's invulnerable from that side.
If they're charging you in the front with calv/Flyers, then stand and shoot them.  At that point, you just need to worry about the one flank, and with access to fairly offensive Lores on Daemonsmiths, and Ash Storm on the Prophet, I've found taking care of the Daemon to not be a huge task.
khedyarl
This is my experience also. I consider my opponents to be a decent caliber and they know what they need to do to lock it down.
I run the cannon exclusively as I feel you give up to much to be able to do a few more wounds to infantry with skullcracker.
Time of Madness:
Problem with the cannon is you need to roll to hit as per the text on page 177.
So even with 10 shots the BS3 means you will be hitting on half of those. Then you need to wound with S6 (don’t roll any 1’s).
Cannon can be useful, but it is by no means a game breaker. It would be nice with the number you rolled on the art dice auto hit as you’d be wounding with most of the shots.
Time of Madness
khedyarl:
It’s by no means a game-breaker, you’re right. It can certainly be a game-changer, however. What you’re missing is the D3 wounds caused. When the Daemon gets within nine inches {Plus six inch move, so a fifteen inch threat} I can’t think of any non-regenerating monster that isn’t going to have a horrible day. even dragons are going to come out of the hailstorm with 4-5 less wounds.
I think it’s a great addition, and does what it needs to do very well. I haven’t experimented with the SkullCracker, however. Anyone have any playtest thoughts on it? I can’t imagine taking it over the Cannonade.
Time of Madness:
khedyarl
Depends a lot on the armies I face as well. I play a lot against Bretonnians, ogres and lizardmen. The iron daemon is not as effective against some of those armies compared to lists that take more infantry based armies.
Time of Madness
khedyarl:
I don’t play Brets often at all, I’ll admit that - but the Lizard players in town generally take between 2-3 Stegadons/ancients, and every ogre has Multiple wounds. The Daemon’s multi-wound killing power hasn’t shown you any results?
Time of Madness:
To be honest I’ve only used it once again lizards and it didn’t do much other then get sucked into combat.
I believe I got shots off against the ancient in one shooting phase, but then they were randomized. Didn’t do enough to put the hurt on the steg before he got the charge off on me.
Against brets it got tied up by a unit of peg knights on the flank.
I’ve had more success against ogres with it, however not getting the thunderstomp really puts a damper on it after the initial charge.
To me the iron daemon is way to situational and I’d rather take a destroyer and hellcannon before investing in the daemon.
Time of Madness
Exxonvaldez:
So what is the verdict on stand and shoot with the cannonade?
Expect an FAQ but until then, the RAW reads, imho, the Iron Daemon can stand and shoot. It is a “unique” unit type so no rules prevent it from standing and shooting that I can see. If it were a war machine, that would be different. Of course then we’d get to use our Daemonsmith reroll on it too. Hmm…
zhatan87:
Expect an FAQ but until then, the RAW reads, imho, the Iron Daemon can stand and shoot. It is a "unique" unit type so no rules prevent it from standing and shooting that I can see. If it were a war machine, that would be different. Of course then we'd get to use our Daemonsmith reroll on it too. Hmm......
Plus the iron daemon should be treated as a chariot (new addition since the experimental rule). Chariot CAN make a stand and shoot reaction.
No doubt the iron daemon can.
