[Archive] Legion of Azgorh vs Bretonnia 2000pts
propervillanz:
My first battle report ever, i hope it is legible and that you all enjoy.  I played the game several days ago so the details are somewhat fuzzy the list i used is under the post “101st Expeditionary Force.” I hope the attachments came through and :cheers.
I apologize for the image sizes, still working on getting the proper format.
[attachment=3347]
Bretonnia kneels to pray allowing the Darwi Zharr the first turn.
All Mounted Yeomen Vanguard forward 12"
[attachment=3348]
Movement:
Both blunderbuss units move up 3"
Magic:
3 power dice vs 2 dispell dice
General IF’s boosted version of spell that gives 5+ scaley skin passes Sorcerer’s Curse test
Shooting :
Infernal Guard Unit 4 fires its Fireglaives at the Mounted Yeomen unit in range doing nothing
Both Hellcannons get direct hits on the Knights of the Realm unit causing 9 hits a piece and the Magma Cannon hits 3 models Ccumulatively causing 7 unsaved wounds.
Magma  Cannon Two hits 3 models  causing 2 unsaved wounds
[attachment=3349]
Movement:
Mounted Yeomen units 1 and 2 move up the western flank and Mounted Yeomen unit 3 move up the eastern flank.
Kinghts of the Realm move up behind the large impassable feature.
Men at arms units move forward one up the center the other into the forest (Fungus Forest) anf fail their stupidity test.
Questing knights move forward up the eastern flank.
Magic:
9 power dice versus 5 dispell dice
Prophetess of the Lake IF’s stone to flesh and losses 2 wizard levels in the process.
Shooting:
Both Trebuchets fire at Hellcannon one and scatter to hit it indiretly causing 1 wound
Mounted Yeomen units one and two fire at the magma cannon causing a wound
Mounted Yeomen unit 3 fires at the hellcannon doing nothing.
[attachment=3350]
Movement:
All Infernal Guard Units move forward 3"
Magic:
5 power dice versus 5 dispel dice
Deamonsmith casts Enchanted Blades of Albain on Infernal Guard Unit 4
General Fails to cast spell to give 5+ scaley skin on Magma Cannon One
Shooting:
Infernal Guard units 1-3 fire at the Men at Arms unit (IG3 gets to fire 30 shots)  causing 6 unsaved wounds all together
Infernal Guard unit 4 fires at the Questing Knight unit causing 2 unsaved wounds
Both Hellcannons fire at the Questing Knights one scoring a direct hit the other scattering to only hit 2 models causing another 4 wounds.
Magma Cannon 2 fires at the Questing Knights doing nothing (Deamonsmith prevented a misfire)
Magma Cannon 1 Fires at the Men at Arms unit doing nothing
[attachment=3351]
Movement:
Men at Arms unit passes its stupidity test and moves ou of the forest.
Men at Arms unit one charges the Blunderbuss unit who elect to stand and shoot (getting 20 shots) and causing 3 unsaved wounds.
Questing Knights charge and assualt the Magma Cannon
Mounted Yeomen units 1 and 3 move about to get into short range
Prophetess of the Lake Fly behind the Tower
Magic:
6 power dice versus 5 dispell dice
Propetess decides to not cast any spells
Shooting:
Trebuchet One gets a direct hit on Hellcannon 2 and fails to wound
Trebuchet Two indirectly hits Hellcannon 1 causing a wound.
Mounted Yeomen units one and two fire at the Magma Cannon causing a wound
Mounted Yeomen unit 3 fire at the Hellcannon doing nothing
Combat:
Questing Knights destroy mamga cannon and overrun into the Deamonsmith
Men at Arms unit causes 2 wounds and the Blunderbuss unit causes 3 wounds loose combat by 2 but hold
[attachment=3352]
Movement:
Infernal Guard units 2 (blunderbusses) and 4 (fire glaives) charge the flanks of the men at arms unit
Infernal Guard unit 1 (fireglaives) move up to absorb the charge of the Knights of the Realm unit.
Magic:
6 power dice vs 4 dispell dice
General casts boosted signature spell from lore of metal Bretonnia uses auto dispell S6 hit item that kills the General Magma Cannon and Infernal guard units pass thier panic tests.
Shooting:
Magma Cannon 1 fires at mounted yeomen unit 2 causing a wound
Hellcannon 1 fires at the Trebuchet one  and fails to wound
Hellcannon 2 fires at Knights of the realm causing and misfires causing result number 3 which lowers the prophetesses wizard level to 0 and causes the deamonsmith to cause a S6 hit on himself and 3 questing knigts killing 1 he then fails his toughness test and dies.
Infernal Guard unit one fires at the knights of the realm causing 3 unsaved wounds
Combat:
Questing Knights overun into the Hellcannon
The Men at arms kill one fire glaiver and loose 8 models in returen, break from combat and are run down by infernal guard unit 3.
Infernal guards units 2 and four reform the former facing west while the latter faces south
[attachment=3353]
Movement:
Knights of the realm charge infernal guard unit one with banner that does not allow stand and shoot reactions infernal guard elect to hold.
Prophetess of the lake moves up in between infernal guard units 2, 3, and 4
Men at arms unit continues to move up the flank.
Magic:
None
Shooting:
Both Trebuchets fire at hellcannon 1 Trebuchet 1 scatters off while 2 causes and indirect hit causing a wound
Mounted Yeomen units 1 and 2 fire at the magma cannon doing nothing
Combat:
The Questing Knights cause 1 wound on the hellcannon via the Paladin while the Hellcannon causes 1 on the unit and holds while questing knights reform.
Knights of the round unit does nothing and looses 3 models looses combat and breaks Infernal Guard elect to hold  and stay in current formation.
nilbog:
Thanks for the report, the images came out fine. Were they done on battle chronicler?
Interesting that magic did very little apart from causing damage to the casters!
I don’t think brettonians can complane about stone throwers when theirs is so good for such a low cost. Chaos dwarfs are still dwarfs, with excellent black powder skills, just with added daemons. Of course our war machines are excellent.
What was your thinking behind shooting the yeomen with the magma cannon isntead of going for the knights? I can see the infernal guard eventually saw the knights off, but wouldn’t it have made it a bit easier if the magma cannon shot at them as well?
Congrats on the win :cheers
rpitts2004:
What was your list?
propervillanz:
nilbog: Yes i used battle chronicler, first time too so i am glade it came through. In terms of magic, I know we were both thinking the same thing, but in all honesty i was very happy with the results (he had dwellers below) and was never able to cast it.  In regards to the magma cannon it was the first time i had ever used a cannon of any sort so was not very confident about it.  Likewise, by the time he charged my infernal guard he only had 3 models left in the unit so i was pretty confident that i could take him.  Plus by that time i was expecting the Yeomen to charge at any moment and was trying to panic them away.  And yeah i was trying to tell him the same thing, but as a dwarf player he denies the very existence of the Uzkul-Dhrath-Zarr.  So when he sees what they can do i think he goes into sensory overload.
rpitts: my list was as follows:
Deamonsmith:(on right side of board)
level 2 (lore of medal)
dispel scroll
Deamonsmith: (on left side of board)
general
charmed shield
talisman of rebirth
Infernal Castellan:
bsb
mask of the furnace
great weapon
pistol
10 infernal guard:
standard
musician
hailshot blunderbusses
gleaming pennant
10 infernal guard:
standard
musician
(bsb here)
10 infernal guard:
full command
fireglaives
deathmask with pistol
10 infernal guard
standard
musician
fireglaives
2 magma cannons
2 hellcannons
His list:
general
level 3 wizard
Pegasus
Paladin:
bsb
banner that adds D6 to the first charge
barded warhorse
great weapon
questing vow
13 knights of the realm
full command
12 questing knights
full command
great weapons
banner that gives a 4+ward save vs shooting attacks
30 men at arms
full command
shield
halberd
30 men at arms
(same as above)
2 field trebuchets
thrawn:
good battle report, thanks! keep them coming.
nice battle report and results. did you think the fireglaive and blunderbuss paid for themselves sometime you seemed to hit with a ton of shots only to cause 3 or 4 wounds. do you think your army would have done so well if he would have been running a more traditional Bretonian list for example, no ranked infantry? brettonian armour and speed is there greatest strength.
Mad Dave:
Great report keep up the good work.
propervillanz:
Thanks for all the positive feedback i will not be playing another battle for another several weeks but will post when i do.
Da Crusha: My army was built around the idea of concentrated artillery bombardment. The whole idea was to destroy the knights to a degree that they would become useless in combat at best, though i would settle for them to simply be manageable (allowing my units to hold for a turn or two). It is built around the idea that i will have a devastating shooting phase so it would have the potential to hold up against an all cav army.
I think a mix of blunderbuss and fireglaives work well depending on the situation, Fireglaives seem great at laying down covering fire and picking off tattered. While the Blunderbusses seem best at creating threat zones and are awesome on a stand and shoot reaction if your dice agree with you.
