Okay, this is my first post on CDO, although I have been scrutinizing its contents for about a week, and have become inspired by all of the fantastic work here.
So, I couldn’t hold back and immediately started hacking up an old (badly) painted BFSP dwarf.
I found the scale mail pretty easy,although I did use the easy square plate technique, however the hair didn’t turn out so well, I think because I flattened the tubes to much in detailing them.
So I have a question, which is better, this method, or the other one I’ve seen, for example on GRNDL’s models, which looks more advanced?
Sorry, I don’t seem to be able to post my pictures, can someone help me? I am a frequent user of Dakka, where I would add the photo as an attachment at the bottom, and I am doing the same here, but it is not working.
Welcome to the site! Looking forward to seeing your first chaos dwarf! Try uploading your photos to photobucket then pasting it onto your post. I’m sure there’s a guide on here somewhere how to do it. Good luck!
To do this look at the “share this photo” box next to your picture. Click on the IMG code in the list and the text will disappear and be replaced with the word copied.
the code you copy should look like the above code. Just past it where you want it (ctrl v).
It is a redemptionist head, from Necromunda, this is one designed for the gang leader/priest, but the heads on redemptionists seem less heroic scale than other minis…
