[Archive] need help painting horns
minty:
start of with schorched brown
then a 1:1 mix of schorched and graveyard
pure graveyard
graveyard and skull white
skull withe
leaving a bit of the last layer showing at the bothem:)
Malificant:
or:
vomit brown
-chestnut ink wash
50:50 vomit brown/bleached bone
-chestnut ink wash
bleached bone
-chestnut ink wash
skull white to pick out the tip.
really water down the bleached bone, and leave a little bit of each previous layer showing when you do the next one.
Khan!:
Or!
bestial brown
bestial + little bit of bleached bone
mix + little bit more bleached bone
etc until satisfied or until:
bleached bone
bleached bone + little bit of skull white to pick out the grain of the bone
I’d have to see the whole model. I have mostly balck chas warriors and so paint the horns silver. However, if they’re bronze, you could try fading it through copper etc or even into the reds instead. Or have balck at the horn base going into brown (which some horns do).
Narflung:
Red horns by Jakob Nielson http://www.jrn-works.dk/
He also has an awesome CHaos dwarf sorceror, the old marauder one.
zorn sabretooth:
Golds a good coulor
two_heads_talking:
a mixture of red horns, gold horns, bone horns and black horns would look awesome. or, disregard the red horns and mix in the other three.
if you did silver tips, you could even do bronze/brass colored horns too with silver tips… (whatever color you are using for your weapons)
KRUG_666:
I like to use Khemri brown…then khemri mixed with bleached bone…
then a brown ink wash…then highlight bleached bone and a little skull white at the tips…
KRUG_666:
Well, any luck?
Post some pics!
Ghrask Dragh:
Things like horns have been made soooooo much easier now thanks to the new washes from GW.
For some smaller horns you can even get away with using just washes, all you have to do is give it a fwe washes of sepia and one final wash of devlan mud over a white undercoat, easy as that! :cheers GW
KRUG_666:
( its too hard to paint when its nice out side)
Kera foehunter
Is always sunny in Southern Cali, best to paint at night though:)
