Samanos:
For those of you who may be interested the new ETC draft came out. it is quite interesting (and dissappointing i have to say) to observe the quite many restrictions CD seem to have (at least i think they do not need these kind of restrictions)
Rules changes:
- Characters will get “look out sir” versus the following spells that automatically kill models or automatically remove an entire regiment: Dwellers Below, Final Transmutation, Dreaded 13th, Infernal Gateway 11-12 effect. Normal requirements for lookout sir apply.
I. General Restrictions:
2400 Points.
No Special or Named Characters.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event
A maximum of 3 identical core choices may be taken (regardless of equipment and other upgrades)
An army may have up to 4 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Max. 45 models with missile weapons with a range of 20�?�+ (not incl. war machines, characters and chariots).
Unit sizes are limited as follows:
Units cannot be more than 40 models nor 450 points (including all command, upgrades, magic items/banners). This restriction applies during the creation of the roster - unit size/cost may be increased during the game (for example - by joining characters to the unit). This restriction does not apply to characters.
Magic Restrictions:
- Apart from Winds of magic, an army may only use 2 PD/DD per magic phase. After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
- Player can use maximum 5 PD to cast spell (+ wizard level). For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
- You may have units/abilities that actually would generate more than 2 extra dice, but any excess dice are lost
- Some magic items/abilities count as generating dice toward this limit.
- �?oCount as�?� items/abilities may never exceed a cumulative 2 PD/DD per phase. This means that player who already spent his limit PD limit, cant take more items which �?ocount as adding PD�?� or add PD from channeling during game (same for DD).
- All modifiers are applied from the army list and will not change during the game.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
If a dice is stolen from the opponent�?Ts pool, but your army has already generated two extra dice, the dice is removed from the opponent�?Ts pool and then discarded.
Some special items and abilities DECREASE the limit of power or dispel dice you can add to the pool. We refer to those as �?ocount as�?� items. What this means is that, if your roster includes one �?ocounts as 1 Power Dice (PD)�?� item, your army can only add 1 power dice (instead of the usual 2 dice) to the pool in each of your own magic phases of the entire game (regardless of whether the item is destroyed or used up).
Please note that you cannot have a combination of items that would decrease the limit of extra power or dispel dice to below zero.
Item restrictions:
- Any item that auto-dispels a spell counts as generating 1 DD each magic phase.
- Folding Fortress is not allowed
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Beastmen can generate 3 extra pd instead of 2. Can use 4 instead of 3 same core units and have a unit cap of 50 models per unit.
Bretonnia: No Restrictions
Chaos Dwarfs
Hellcannon 0-1
Iron daemon, kdai destroyer and every model with hashut lore count as war machines
chalice of darkness counts as 2 pd
Max 3 out of lore of Hashut, s5 war machine templates, destroyer, iron daemons.
Chalice or Sorcerer Prophet
Flask counts as 3 war machines.
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows (including characters and excluding chariots) in the army. Repeater Bolt Throwers 0-2. Flying units (inc. characters on flying steeds) in the army limited to 0-3. Harpies are 0-2. Shades max 20 models per army, Pendant of khaeleth cannot be taken by lord characters, player may take up to 2 of following: Pendant of khaeleth\Crown of command\any number of wizards using death & shadow magic\Cauldron of Blood\Hydra.
Dwarfs: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2; 0-3 of anvil, miners & rangers (in any combination of them)
Daemons of Chaos
Max. 30 Models per unit; Flamers are a 0-1 choice. All daemonic gifts are 0-1. Bloodletters and Herald of Khorne are 0-3 total. Daemonic Battle Standard can take either daemonic icon or gifts. Siren song cannot be taken by Herald of Slaanesh. Master of sorcery cannot be taken by Herald of Tzeentch… Max 6 flamers in the army. Mos: Rule change: It doesn’t give loremaster lore (can take any rb lore)
The Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are a 0-1 choice. Max 2 cannons, steam tank count as a cannon.
High Elves: High Elves armies have an extra 100 points for their roster (2500 total); High elves army can generate extra 3 powerdice instead of 2; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice;Scar-Veterans 0-2, Terradons and Stegadons (any kind) are 0-2 choices; player may take up to 2 of following: Beclaming Cogitations\ Focus of Mystery\ Focused Rumination \Higher State of Consciusness; Beclaming Cogitations counts as +2DD; Cupped hands of the Old Ones counts as +2PD; Higher State of Consciusness counts as 2 discplines (takes two slots, but cost same points); Crown of Command & Higher State of Consciousness cannot be taken on 1 model; A maximum total of 6 Skink, Chameleon skinks and Skink Cohorts units combined maybe taken in an army (Cohorts containing kroxigor or numbering above 20 models do not count for this restriction). Max 1 of these in army death lore/bane head/feedback scroll
Ogre Kingdoms: Hellheart counts as 2dd & 1pd, Greedyfist on death mage counts as 2dd. Each leadbelcher/ sniper maneater with pistol(s) counts as 3 models towards to shooting cap. Max 3 combined units of Mournfang Cav & Ironblaster. 0-1 Ironblaster.
Orcs&Goblins: Night Goblin Shamans(0-3 cap removed) mushroom dice do not count as power dice in regard to the PD limit. Maximum model cap is 60 models per unit. +100 pts.
Skaven: All Skaven rare choices 0-1; Gutter runners are limited by 2 units & 20 models total; Engineers are a 0-3 choice; Can take max 2 of the following: doom rocket, brass orb, storm banner;
Vampire Counts
Master of black arts & blasphemous tome upgradeare 1pd each. 0- 3 etheral units (incl. Heroes). 0-2 red fury and/or quickblood abilities. 0-4 howls (death shriek counts as 2)
Tomb Kings: Tomb King armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Neferra’s Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it’s alive. Sphinxes of all kinds: 0-3 per army. Tomb Kings may generate up to 3 power dice per phase
Wood Elves: Wood Elf armies have an extra 200 points for their roster (2600 total) All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Wood Elves can take 4 of the same core unit instead of 3, Wand of Wych Elm counts as +1 DD; Only Glade guards (including scouts) count for max of 45 models with shooting weapons
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. If you have warriors, knights and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods.
II. Pairings.
1. (1&2th match up of Team A v. Team B)
Both Teams put up 1 army.
Both Teams put up 2 opponents
Both Teams choose their match
2. (3&4)
3. (5&6)
4. (7&
Not chosen army of Team A plays against Team B last army («in hand»)
Not chosen army of Team B plays against Team A last army («in hand»)
III. Scoring
Victory points scored as per the rulebook, with the exceptions that:
- units that are at 25% or less of their original models yield 50% VP’s to the opponent (characters, monsters and handlers, war machines and single models are unaffected).
-units that are fleeing at the end of the battle yield 50% VP’s to the opponent.
In both cases, bonuses (for generals, banners, etc.) are not counted towards the 50%. Units that are both: fleeing and at/below ¼ strength still only yiled 50% VP�?Ts.
0-20 Victory-Points per game
60-100 Battle-Points per team, except for the last round, when the lower limit is dropped.
(The losing team gets 60 points even if they score less[except in the final round] �?" the winning team never gets more than 100 points, even if they score more. Real Battle Points
