[Archive] Re: War Machines & Line of Sight
Novos:
Hey all!!!
I just had a few questions about LoS for our war machines. I know The Magma Cannon counts as a cannon so it can target areas in front arc but not necessarily within LoS.
Does this also apply to our other machines? More specifically the shrieker and the hellcannon? Can I drop a large template in the center of the unit if I am not elevated? Or would the center have to be at the front rank?
Also just to clear up the demolition rocket hits both the rider and mount correct?
Thanks all!!!
Grimbold Blackhammer:
All war machines need to be able to see the point at which they are firing. Some war machines have rules for indirect fire but you’ll have to look those up on a case by case basis.
A Demolition Rocket is an infinitely small template that hits one model. So both the mount and the rider would be hit however he would get a Look Out, Sir! roll if applicable.
