Alric:
is in the Chaos army and GW is not sharing units between armies , does this mean a chaos dwarf army wont have a hellcannon ?
Alric:
Probably not in its exact form, no. But I would imagine some kind of comparable Daemon-engines that work along the same principles.
Pyro Stick:
Chaos Dwarfs will probably get something more reliable than the hellcannon. Or a more reliable version of the hellcannon if they get it at all. Maybe GW will still give chaos dwarfs the hellcannon but with slightly different rules to make it a bit weaker but less likely to eat its own army.
The Hellcannon doesn’t eat friendly units anymore (except its crew - but all war machines present a risk to the crew).
They are still doing “sharing”, the Manticore is an obvious example of one being in two new books. They are just doing complete books, so you don’t have to buy two books to get all the Chaos rules.
I could see us getting it. The distiction alric might be alluding to and others is the O&G part of the equation.
Disciple of Nagash:
I would have thought you would still get it. As mentioned there are many units that do cross over into many different armies, especially when it comes to warmachines. Perhaps the rules might be tweak slightly.
One thing I would have thought, is that they give CD something similar to runes. After all I can’t imagine them loosing that knowledge.
There tends to be some sharing with minor stuff like mounts (lots of armies get horses…) and in certain special cases like Chaos monsters. As I said though, I wouldn’t imagine the Hellcannon appearing verbatim in a hypothetical Chaos Dwarf book, as it’s likely to be part of a wider trend of Daemonic engines instead of being a bizarre special case.
I would have to agree with Thommy, it may appear as a stand in model (until one is done in plastic a loooong way down the line), but it would not be the same rules wise imo.
I.e. Rare Slot: Daemonic Siege Cannon. GW don’t release any model for this with a new army, nor do FW. They do however remind people that they can use the Hellcannon model as a counts as siege cannon until they get round to doing it.
At the very least if they are to copy it over they better sort out the rules properly so we don’t need pages of eratta and FaQ.
Black Orcs, Goblins and Orcs I think will all be taken out.
i say let them have it ! it not that great of a weapond
Border Reiver:
So long as the earthshaker remains unchanged, I’m good.
Weren’t the Hellcannons specifically built to order for Archaon during the Storm of Chaos? (i.e. as opposed to something that the CD just had lying around and that they would themselves normally use)
Weren't the Hellcannons specifically built to order for Archaon during the Storm of Chaos? (i.e. as opposed to something that the CD just had lying around and that they would themselves normally use)No - they're just something the Chaos Dwarfs build for the Warriors of Chaos according to the current Armies book. It's not clear if they'd use it themselves but then, in the WoC book, it isn't even mentioned that Chaos Dwarfs have their own armies.
wallacer
maybe where going to use the 3 barrow hell canon ???
kerbak:
One thing I would have thought, is that they give CD something similar to runes. After all I can't imagine them loosing that knowledge.I feel on the same way,, a race so prought of them selves as Dwarfs, must devolep an own way to make rune once they become to chaos,, and that is the way the suppose to made chaos runneshield or armour... a new background could be that new chaos runnes develop in a different and porwerfull way, that now just a few know them and can handle them, and are just written on some of the powerfull equipment... or something like this,, and this will justify all runic items
Disciple of Nagash
