[Archive] Too many Questions
deadlydeceiver:
Hi there,
for the first time since the release of the 8th, the LoA made me wanna play Fantasy again. So here I am with a nice collection of (very expensive) models and a lot of minor rules questions.
First and probably most important:
If a (hellbound) Dreadquake with attached slave ogre looses wounds, how are these allocated? Is the following possible: First the hellbound-wound, then 2 on the orge, then the 3 Dwarfs and in the end an ogre with 1 wound left mans the mortar by itself and I keep the bonus?
2nd:
Does the magical weapon of a lammasu rider, loose it’s abilities? If yes, what about a darkforged weapon?
3rd:
Infernal Guard keep their shield no matter the chosen options (GW/Fireglaive/BB), right? Although the fireglaive-models come without shields…
4th:
If a sorceror, who’s part of a unit ist affected by ashstorm, may he cast spells on his own unit?
5th, also very important:
If a Demolition Rocket hits a monster with rider, are both hit or only one (distributed as shooting)?
6th:
What the heck ist the CD “Overseer” mentioned for? (FAQ says the IG-Champ is a real Deathsmark)
I’m very sorry for the wall of questions, but I couldn’t get any answers in my usual (national) forums or find them anywhere else.
Oh, one more: Are K’daai Fireborn supposed to be on 40mm bases?
Thanks alot in advance
DD
  1. It’s not clear how Wound allocation works in this case, as FW seem to have missed the part of 8th Edition where crew models are just markers for war machine Wounds. I would say you’d have to remove complete models where possible, so the first Wound is your bonus Hellbound one, then remove the Ogre after the next three Wounds, and finally remove the Chaos Dwarfs as normal.
    2) Nope.
    3) Yep.
    4) Don’t think so - it stops casting altogether, doesn’t it?
    5) It’s a template (even when it’s just a “marker”) so it hits both.
    6) It’s a typo, hence the FAQ.
    7) Probably.
Nicodemus:
Thanks ThommyH - it’s great we can consistently rely on you heading up a lot of these questions so quickly! I think ThommyH is on the money with all of these, deadlydeceiver.
For question 5, think of the “template” as being the tip of a pencil/pen. It’s just a point that you’re targetting, but it’s still effectively a template with no radius.
For your K’daai question, our most recent contest (Golden Hat 16) allowed people to go with either 40mm or 50mm bases. As of right now, it’s anyone’s guess until FW release some K’daai models. Given that FW loves spectacle, and are already (reportedly) going with 50mm bases for their Bull Centaur models, chances are somewhat good that it’ll be 50mm… but they’re your models, make 'em what ever size you want :wink:
Rickie:
#4 A mage in a unit targeted by ashstorm can still cast spells, but only ones directed at himself.
Regarding the lamasu, as writen in the SM book you could interpret it as he lose his magic weapon. The wording never considerd the monster being mounted. Dont know if there is a faq, or some sentance in the brb that makes it ok thou.
A model isn’t in base contact with itself.
deadlydeceiver:
First of all: Cheers to all of you for answering this fast.
1) It’s not clear how Wound allocation works in this case, as FW seem to have missed the part of 8th Edition where crew models are just markers for war machine Wounds. I would say you’d have to remove complete models where possible, so the first Wound is your bonus Hellbound one, then remove the Ogre after the next three Wounds, and finally remove the Chaos Dwarfs as normal.
Thommy H
Hm, sounds reasonable, but couldn’t I aswell remove the Dwarfs before the Ogre, to keep the “no roll needed”? (Admitting, it would be quite strange to have a slave crew a warmachine all alone.)
2) Nope.
Thommy H
That’s what I assumed aswell.
3) Yep.
Alright! My opponents have to deal with it… :hat off
Rickie
So I’m still unsure ist his unit part of “himself”?
I need a second Deathshrieker… :cheers
Yep, I know, but why is he mentioned in the bestiary? Makes no sense to me…
Nicodemus
Crap, that would be so FW. I just got convinced, that Monsterous Inf is mostly on 40mm, so I started converting… and now I’m undecided again.
Thanks to the “Blazing Body” the basesize is quite important with the K’daai…
One question I forgot: A Taurus gets hit by a scatterd flame pilar (? - 6th Spell Lore of Fire) Does he regenerate? He wasn’t the “target” of the spell in the beginning, but now he’s hit…
Again thanks alot for helping me out.
DD
A model isn't in base contact with itself.
Thommy H
+1 I pretty much agree with everything Thommy has said.
except of course, wizards can still casts spells but only on themselves and I would remove the crew as I like, preferably 2 cds first.
Yep, I know, but why is he mentioned in the bestiary? Makes no sense to me...
Yeah, it's a typo. That's what the FAQ is correcting. They obviously changed the name between drafts or something and missed a couple of references. Re: Ashstorm - "himself" means exactly that. His unit is not "himself", even though he would be included in any spell that affected the whole unit.
Grimbold Blackhammer:
I’m actually at a loss to think of any spells a victim of Ash Storm could cast except the #6 Lore of Beasts spell and Throne of Vines. Maybe there are more I’ve missed… Keep in mind when a unit has Ash Storm cast upon it, a Wizard (except for a Slann - sucka!) can just leave the unit and be free of the spell’s effects though he would have to make a Dangerous Terrain test to do so. Od course then he is alone and vulnerable but at least he can cast.
Rickie:
As I said, was unsure on the lamasu part, english not being my native langues.
Point number 4 stands thou. In brb you will find that some spells targets just the mage, and I belive some target himself and his fellow unit.
Dont have the rulebook lying around at the moment but spells like cascading firecloak, steed of shadows, earth blood and throne of wines should all be ok to cast.
Nicodemus:
One question I forgot: A Taurus gets hit by a scatterd flame pilar (? - 6th Spell Lore of Fire) Does he regenerate? He wasn't the "target" of the spell in the beginning, but now he's hit...
deadlydeceiver
I think most folks would accept that he is able to regenerate. The wording in the Tamurkhan book does specifically state that if it's the "target of a successfully cast" Lore of Fire spell, that it can regain some lost Wounds. I don't think it matters that he might not have been the intended target initially identified by an opponent (or yourself), but after scattering a template it's possible that he could become the target, and that satisfies the requirement.
I'd find it really damn odd if someone wanted to argue that a model with the Fuelled by Fire special rule that ended up under a Lore of Fire-related template after it scattered couldn't regain Wounds becase he wasn't the target they picked! Then again, there's some really whiny players out there and sometimes you just have to suck these things up to just get through the game without them having a big hissy-fit and totally ruining it ;) I played against a guy like that at our local FLGS. I was still relatively new, and he'd been playing for a long time, but he just made his own interpretations to suit himself, put in a show like he was the best in there and knew the rules so well that I was the idiot for even questioning his interpretation, and he was really obnoxious when it came to settling rules/conditions disputes or showing off for other people in the store. Funny that every single little thing that came up worked in his favour :P I could have gotten mad and told him off, but he was such a loser it wasn't worth the effort - I just knew that would be our first and last game :P I just kept my head down and hammered my Dawi'Zharr into his favourite units instead.
Ragnarov:
Question, not for rules :slight_smile:
Somebody knows? Has Forge World shops in London?
I think you might be able to pick stuff up in person from Warhammer World in Nottingham, but really the best way to buy it is to order online.
Ragnarov:
Thanks, but I will be in London in work-trip. I going buy something. :frowning:
Vogon:
Question, not for rules :)
Ragnarov
No, the only place you can buy Forge World off the shelf is Warhammer World in Nottingham.
Sorry :(
eudaimon:
But you could pre-order in advance, and get it delivered to a GW store in London for pickup.
Actually, that would have the same effect as ordering it to home, excpet you would have to go to the GW to pick it up. Only the GW products get free delivery to the store etc. Otherwise, it will be delivered to the address of the store in the same fashion as your house (I.E. Not a web-order).
