Magma cannons close to done. Instead of some lava “watergun” I imagine the shots like some sort of fire deamons trapped in crystals.
Im planing to do one chaos dwarf per gun and some random slaves as crew (I really want to make a chaos dwarf thats beating the living&(#% out of an elf)
You’re doing fine, keep on detailing the guns and don’t forget the wheels and they’ll be really sweet! That Magma cannon battery will be fearsome.
By the way, you could test to do some damaged rocks on the K’dai by applying a drop of plastic or super glue to the foam. If you try it, do it on a loose part of foam first, because otherwise you might want to remove an already glued-on foam piece.
Slowly working on the fireborn, bad pic of the heads I know. Will get back to them later. And I got myself some mantic games dwarfs to make some CDs out of :hat Too bad the shields look like &"%&" I need to find some other shields.
