I was wondering if there are any companies that you are aware of which have goblins on wolves?
The GW models are an option of course and Mantic has the “fleabag” riders.
Blacktree Design sells some metal models.
What other companies might have options that would work well in a limited budget? I would ideally like to build 2 Khans and have two units of 5 wolf raiders as options.
If you’re not averse to kitbashing, how about Fireforge Mongols mounted on GW plastic wolves (fairly sure you can still buy them separately from GW, or failing that a bitz seller) with a head swap (either bitz order goblin/Gnoblar heads or sculpt your own)? There’s twelve mongols per box, so that covers both khans and both units you want to make.
If you're not averse to kitbashing, how about Fireforge Mongols mounted on GW plastic wolves (fairly sure you can still buy them separately from GW, or failing that a bitz seller) with a head swap (either bitz order goblin/Gnoblar heads or sculpt your own)? There's twelve mongols per box, so that covers both khans and both units you want to make.
Dînadan
Hmmm. Will look into this. Thanks for the suggestion.
