Starting another Army. Some of you might remember my SoBH Harryhausen themed warband from the old forum. I’ve been randomly collecting models for a related Ancient Greek themed army since I painted that force. I plan to play them using the Kings of War Historical rules. I should have enough units with what I’ve collected to do a 2k pt force with 500-750pts worth of swappable models if I want to make the force into a quasi fantasy force with units from Greek mythology. Some of the mythical units will draw their origin more from early Greek myth based stop motion movies than from mythology.
A few years back, one of the lots I picked up was a partially assembled Greek troop lot of about 60 models on eBay. Early last year I finished assembly on the lot, then it sat on my short list, but unfinished the remainder of 2022
Dec 2022 I painted up a few units worth of test models. I only finished 3-4 of them, but the remainder will be done before end of month. What you see here is a combination of the following:
Around 70 Wargames Factory and other manufacturer troops. Mostly assembled. Mostly spear and swordsmen in varying states of armor to represent Leavy, Standard, and Heavy units. 12 models test paint in progress
Wargames Factory Amazon’s. Mostly unbuilt. 2 built with bows. Now OOp and hard to find models, but the armor matches the Greek styling. 2 models test paint in progress
Dreamforge Temple Guard with spears. Will likely play as a heavy spearmen unit. The unit commander is a Reaper bones conversion. 3 models test paint in progress
Tale of War Spartans which will be expanded into a larger unit to be again played as Royal Guard. 3 models test paint in progress
A Darklands Talos and Hydra from the original KS
A couple of Reaper bones Storm Giants
12 cavalry Victrix, 12 centaurs (lt cavalry), and 12 fauns (skirmishers; a mix of models I had, some from the centaur sprue, Reaper bones, and several older models that are missing heads and such); unassembled; will likely convert a unit or two of troops to heavy centaur cavalry (still need to pick up horse bits for that; have everything else)
Some giant scorpions; per the Harryhausen Clash of the Titans. Have 2 (still need to pick up other appropriate models)
A unit of Kelt Barbarian archers from Confrontation to use as Cretan Archers per the KoW rules
Cheers!
