The Muspelzharri host crafted in the Caffeine Forges!
(Excuse that dumb joke I made in the topic’s title :smiley: )
Ello, ello, elloooooo! I am Caffeine_Forge, otherwise Formula_C8H10N4O2 in the discord server, and this will be my army blog! Going over my Helsmiths of Hashut army and other such projects which, given my pace at painting minis, I’ll be updating this blog for a long long while into the future :wink:
So, first of all, the colour scheme. I like painting my armies after official in world subfactions, with a few changes here and there for personal preference, as I do not trust my judgement to pick colour schemes and I like using the lore as inspiration.
For my Helsmiths of Hashut, the Ziggurat of Muspelzharr is what my Zharrdron will be!
References for the Scheme
Denizens of the Realm of Metal, a perfect place for our evil industrial dwarfs, I felt they were a perfect pick especially with their black, yellow and red colour scheme. It called to me.
Taking the Realm of Metal as inspiration for the base scenery, I wanted to incorporate that in my armies base scenery. And then the idea struck me. Iron mines.
Base Scenery Inspiration
And so, from there, my plan for my armies base scenery is to give them a sort of red-earthy tone to hint at the iron beneath their hooves. From there, I began to push the idea to try and think of how I could make it look like it’s underground, such as having some braziers here and there to act as light sources, some red crystals and mine carts to help push the whole underground vibe. For some of the more important minis, to bring in a bit of the AoS high fantasy element, I’ll try and use green stuff to create metallic rivers of liquid metal (Aka Chamonite, the Realmstone of Chamon, visually looking like a floating blob and sphere of liquid silver or mercury).
If I stick with all these ideas… we’ll have to wait and see.
Here’s the minis I’ve got for the project at hand.
The Pile
Given how my current painting progress is… exceptionally slow, a single infantry unit taking me a few months to complete, this will be a loooooooong process. Heck, might make it a challenge to see which I complete first, this army or an entire programming course.
My plan is to go through most of the infantry first and foremost, after that I’ll probably do either the artillery or the heroes. Next the mighty Dominator Engines, then the Daemonsmith of Infernal Taurus. And finally (I’ll probably buy and paint a few other units before this), Kitbashing a Zharrdron Cogfort. The Spitewood box is specifically to use for said Zharrdron Cogfort, with High Despot Zuldrakka The Hateful leading it and most of the Blood of the Bull accompying her somewhere on the Cogfort.
Anyway, onto my actual painted minis.
The First Test Mini
I was fairly proud of this first test mini. Plenty of things I wasn’t the happiest with and wanted to change but that’s the entire point of doing a test mini in the first place.
My recipe for yellow… I was not happy with. Found it to be a rather ugly shade of yellow, too green for what I wanted. I had used Screamer Pink as a base, drybrushed and layered White Scar on top and then used Imperial Fist Contrast paint. Following that, I used Yriel Yellow as a highlight. I think the problem was using screamer pink, as it was too dark and leaned too much towards purple then pink.
The red gem, I was both happy with and upset with. The actual black to red gradient I was quite happy with as a first attempt at doing gems, though maybe in the future I’ll try and push it more towards red. But the orange at the end, as well as my attempts to do some highlights, messed it up.
The partial molten metal effect I tried to do with the spear was okay, just need to get better at it.
The grilled chamber on the spear, I went a bit too heavy with the red contrast paint. I want the red to slightly spill out as a sort of glow, just not completely drown the entire section. Think in future, I’ll only apply the red contrast paint into the main glowing sections, then either feather it out or use very very thinned down contrast as a sort of shade for the surrounding area.
But, on the up-side, everything else I was largely really happy with. Especially the black metallic armour, I am normally terrible with highlights but those highlights aren’t completely horrendous.
Test Flames
For my army, I plan to give them red flames. Not normally flames of red, orange and yellow. But Red flames, a supernatural and magical red fire. To do this, my plan was to use pink and purple (with white and black here and there). But as I couldn’t find any reliable reference online, I had to do some experimenting. I’ll admit, the difference isn’t obvious, but I was testing to see if the idea even worked as well as testing the order of the flames. If it should be Red → Pink → Purple or Pink → Red → Purple. Felt I needed to test this as, in my brain, pink felt like the obvious choice for the ‘hottest point’ of the flames buuuut looking at painting guides for flames and most colour wheels, pink is technically a colder colour then red (I think, I am not a expert in colours).
But, with the test, I think I’ll go for the Pink → Red → Purple sequence. Where red is the midtone and the majority of the flame, pink and white will be the hottest point in the recesses while purple and a little bit of black will be the ‘coolest’ point near the tips of the flame.
Also, with these Braziers that I 3d Printed at a local hobby store, I plan to use them as Desolation Tokens for my army.
Hobgrots, Demoted to Test Minis
These hobgrots were not meant to be test minis, heck they took me most of this year to paint, buuuuuut I messed up in so many ways with them that I decided to turn them into test minis and that I’ll replace them in the future with other hobgrots.
Major issue, took me forever to base them by hand. So, they taught me a valuable lesson, to actually get a damn spray can for once.
Second… I tried to sub assemble them but I used blu-tack to cover the contact points, so when I finally removed them from the blu-tack the paint started to rip and come off.
The base scenery is way too large, I need to shrink that down in the future. Plus I need to glue the models on before I start applying the basing sand, as I thought I kept enough level space for them to stand buuuut it was painful trying to glue them on. So for future reference, I need to do the base scenery after I glue the models on.
But, I will say, I am extremely happy with the yellow. The previous yellow was ugly, ew, no. This one? I am so much happier with this shade of yellow. Swapped out the Screamer pink for Emperor’s Children, swapped the white scar for Fulgrim Pink. Emperor’s Children as a base coat, Fulgrim Pink as an all over layer, then Imperial Fist. After that, used some very thinned down Yriel Yellow as a careful glaze here and there on more elevated areas, before doing a final highlight with Dorn Yellow.
What I'm Currently Working On
I’m very slowly working through a unit of Infernal Cohort. Unfortunately there’s a bit of texturing caused by the spray prime I did but nothing too bad. Hopefully within a week or two I’ll have the base coats done (just need to finish the gold base coat, do a bit of silver on a spot I missed, then paint the flame white).
Already think I’m going to change something in the future. I’ve subassembled it with heads and shields separate but in the future, I think I should just keep all their arms separate (plus a handful of other things like keeping the brazier on the banner separate). Glue the arms to the shields, then keep all the arms as their own sub assemblies, as that should make things a lot simpler as well as make sure nothing is in the way.
As a quick note for these Infernal Cohort, as well as all Dwarfs/Duardin I’ll be painting for this Helsmith army, I’m giving them varied features to help break them up. 2 different hair colours, 2 different eye colours and 2 different skin tones. White hair and black hair, red eyes and orange eyes, lighter skin and a more tan copper sort of skin.
Mineral spirits can take that off in the future. If it shows up in the prime, remove it before you start painting and reapply. It can happen if it’s really humid or if the can isn’t shaken really well…
You can’t go wrong with black and yellow, that muspelzharr scheme is a classic. It’s cool to see the pink undertone–>bright yellow technique get used more and more I loved it, but I can see why screamer pink didn’t quite get the result you want. Thick as it was, I got a great result using a 5 dollar glossy pink spray paint from target funny enough, I was always looking for that insanely bright pink for as much contrast as I could get. Only doing the yellow on sashes is an interesting challenge and doing it right next to so much black is going to take some patience. They’re looking really excellent though.
Great to see more Helsmiths.
One thing I’m unsure if I should or shouldn’t tweak and change about my Helsmiths paint scheme is the black armour.
Currently my recipe for it is Iron Warriors Base → Black Templar All Over → Stormhost Silver Highlight.
It works as is, though I could try and make it more detailed with a drybrush of Leadbelcher and a shade with Nuln Oil before the Black Templar application, to hopefully add some lighter and darker area’s. Main worry is that the Leadbelcher would be too bright and might mess up the pitch black look.
Have you tried these? Might be the solution you need…
True Metallic Metal
Progress has been slow but I think I’ve finally got all the base colours done and sorted.
Next step will be the red and orange eyes, afterwards the light and copper-olive skin.
Painting the eyes surprisingly didn’t take too long.
They’re not great work but I think they’re mostly alright?
