Hi guys!
do you know where I can find transfer sheets like this one? (not necessarily original gw). Thanks!
So apparently this exists. Not a great resolution and I am not sure from which catalogue this is (a quick reverse image search did not yield anything) but better than nothing. If you are willing to put in some effort, you could try to upscale this, change the colors and create your own transfers.
Holy crap, the dithering!!! I don’t have a lead on where to get more transfers, but I own all of these and have scanned them.
With high res scans and an ink jet printer you can make your own… plus new versions too.
Here are some better scans:
https://chaos-dwarfs.com/wiki/index.php?title=Banners#Chaos_Dwarf_Symbols
Significantly better scans of all 5 are coming. Just cleaning them up and removing the blue background for printing.
Keep an eye on the forum. I’ll find a home for it some where.
[Edit] Update here: Chaos Dwarf water transfer decals [8583n]
Hi Gents, how do I get access to the 5 scans kindly provided?
Thanks
you need higher resolution than the ones available at Chaos Dwarf water transfer decals [8583n]?
