[Archive] 1k pnt amy list and a strategy to go with it
Cryozen:
ok, heres the list (which has ben updated, yet again to fit suggestions)
94 - CD Hero
������������ Add Hand weapon
������������ Armor of Gazrakh
105 - CD sorcerer
������������ Dispell scrollsx2
Core
210 - 19 CDs
������������ Full command
210 - 20 CDs
50 - 25 Hobgoblins
������������ Birthday suits (nothing)
50 - 10 Hobgoblins
������������ Bows
120 - 10 Hobgoblins
������������ Wolves
������������ Musician
Special
60 - 2 Bolt Throwers
Rare
110 - Earthshaker
Strategy, first here is the battle field and my basic troops lay out
M = melee units
S = Shooty gits and artillery
W = Wolfriders
|���������� |���������� MMMMMMMMM|
|������W������������<— W������������ |
|���������������� SSSSS���������������� |
so here is the plan, before i move my melee units into position i pound the snot out of the enemy with my mighty artillery! then i stack the flank of the table with my melee allowing just enough room (looks like i left plenty on the diagram) for my wolf riders to slip by and rip their casters and artillery bits to little goblin chunks . . . or what ever else im playing. for larger games i plan to through in a centaur lord to accompony the wolf riders and another earthshaker or so.
what do you guys think?
((EDIT)) the naked hobs are going to be used for either taking the brunt of an attack or to flank a unit that needs support
Theory_Man:
Hobgoblins need to be in units of ten or more, even if they are on wolves.
Cryozen:
damn, your right. forgot to check the whole minimum models thing >.<
aside from that, what do you think?
Theory_Man:
Do you plan to put you heroes in your CD units? If so are to planning units 7x3 with the 21 models? You might what to have the units be 19 strong, save some points for other things, like bring your wolves riders to ten strong.
What are you planning on doing with 25 hobgoblins?
Malificant:
also 20 chaos dwarves w/ command are 210 points. that 20 points is huge in 1k. almost enough for your 2 wolves.
Cryozen:
ok, ill take you info into account and change the list now
Uzkul Werit:
Wow. That list is pretty big for 1000pts considering you have two heros. However drop the Standard on the Wolfboyz and give them a musican. Not only was the standard basically free VPs for the other side but a musician is handy for rallying.
51la5:
Drop the wolf standard and get a musician drop the musicians on the warriors they are not worth the ten points each drop the chalice and get two dispel scrolls the chalice is best used offensively replace the addition hand weapon on the hero with a shield so you have enough points for another bolt thrower.
Theory_Man:
51la5
Musicians are not worth it? Yes they are, especially because 40% of his points are in theses two units.
51la5:
Not at 10 point 19 if you include the cost for the basic warrior.
Swap the chalice for a dispel scroll or two, swap the standard with a musician on the wolves. Apart from that it looks good.
