Nurion:
The problem with this list is your blunderbuss
Sadly your not allowed to bring a unit that cost over 450 pts with ETC comp
Which is allso why blunderbussunits are rarely seen with this comp
Otherwise it looks good!
Nurion:
NemesisCH:
Damn, i knew i missed something. Thats the problem with the AB, you dont check always the tournament comp. โฆ
Hope i got it right this timeโฆ
2400 Pts - Chaos Dwarfs Roster
Total Roster Cost: 2399
Sorcerer-Prophet (1#, 400 pts)
. . 1 Sorcerer-Prophet, 300 pts = (base cost 265 + Level 4 Upgrade 35)
. . . . 1 Enchanted Shield, 5 pts
. . . . 1 Sceptre of Stability, 15 pts
. . . . 1 Talisman of Preservation, 45 pts
. . . . 1 Crown of Command, 35 pts
Daemonsmith Sorcerer (1#, 125 pts)
. . 1 Daemonsmith Sorcerer, 95 pts
. . . . 1 Charmed Shield, 5 pts
. . . . 1 Dispel Scroll, 25 pts
Dark Castellean (1#, 207 pts)
. . 1 Dark Castellean (Battle Standard Bearer), 132 pts = (base cost 105 + Shield 2 + Battle Standard Bearer 25)
. . . . 1 Biting Blade, 10 pts
. . . . 1 The Mask of the Furnace, 65 pts
Hobgoblin Khan (1#, 61 pts)
. . 1 Hobgoblin Khan, 56 pts = (base cost 40 + Wolf 12 + Light Armour 2 + Shield 2)
. . . . 1 Dragonbane Gem, 5 pts
Hobgoblin Khan (1#, 79 pts)
. . 1 Hobgoblin Khan, 54 pts = (base cost 40 + Wolf 12 + Light Armour 2)
. . . . 1 Shield of Ptolos, 25 pts
. . . . 1 Warrior Bane, 5 pts
Chaos Dwarf Infernal Guard (24#, 320 pts)
. . 23 Chaos Dwarf Infernal Guard, 296 pts = 23 * 12 (base cost 12) + Musician Mus 10 + Standard Bearer Std 10
. . . . 1 Deathmask, 24 pts
Chaos Dwarf Infernal Guard (23#, 446 pts)
. . 22 Chaos Dwarf Infernal Guard, 416 pts = 22 * 18 (base cost 12 + Hailshot Blunderbuss 6) + Musician Mus 10 + Standard Bearer Std 10
. . . . 1 Deathmask, 30 pts = (base cost 24 + Hailshot Blunderbuss 6)
Chaos Dwarf Magma Cannon (4#, 170 pts)
. . 1 Chaos Dwarf Magma Cannon, 170 pts = (base cost 145 + Hellbound 25)
Hellcannon (4#, 205 pts)
. . 1 Chaos Dwarf Hellcannon, 205 pts
Kโdaai Destroyer (1#, 325 pts)
. . 1 Kโdaai Destroyer, 325 pts
Composition Report:
Points of Lords: 400 (0 - 600)
Points of Heroes: 533 (0 - 600)
Points of Core: 766 (600 - Unlimited)
Points of Special: 170 (0 - 1200)
Points of Rare: 530 (0 - 600)
Geist:
I like the list but, the blunderbuss unit just wont give you what you want. Short range means you take damage getting in range, and as soon as you loose 4 dudes you loose reroll power. Problem is the comp is making blunderbusses hard to make useable. I will say it again, ETC is bullshit. As long as you have that leash digging into your neck you wont be able to make a proper list. ETC is not warhammer.
NemesisCH:
I played that list two days ago against a ETC dwarf list. It worked very good, but i know, dwarfs are โeasyโ to deal with.
This weekend, at SAT i will have a game against a vampire army and at SUN its trournament time. I will report back here.
Honeym123:
I played that list two days ago against a ETC dwarf list. It worked very good, but i know, dwarfs are "easy" to deal with. ;)Hi man,
This weekend, at SAT i will have a game against a vampire army and at SUN its trournament time. I will report back here. ;)
NemesisCH
