Why not make the castellan the bsb and give him the enchanted shield for a 2+ save followed by the 4+ward save. Better yet give him the mask/shield combo and leave the talisman of preservation/enchnated shield combo for the prohpet.
What units are the characters going in?
I’d drop hellbound from the shrieker and use the points to better outfit the characters.
In addition to what Time of Madness mentioned, your Sorcerer-Prophet has the Other Trickster’s Shard. Are you planning on sending him into combat? I also question putting the Dragonhelm on your Hobgoblin Khan. I know those poor guys get no love but assuming he’s just a speed-bump, he doesn’t need any gear. And 70 points for what he’s destined to do seems like a lot.
Missed the fact that he was my BSB and he had a shield… he now has warrior bane for a magic weapon and have given him the Dragonhelm. Have swapped the other Tricksters Shard to the BSB also.
The Khan now has no spear but has the Dragonbane gem. The 2+ ward to flaming is amusing, I have had one charge my unit of flamers in my Doc army and hold it all game ( IT might even hold a Kd’aai Destroyer for a couple of turns.
From playing one game with a different list and having played CD armies 4 other times I found that the blocks eventually get into combat anyway so thats why the other tricksters shard.
The deathshrieker has hellbound for the magical attacks for Wraiths / Hexwraiths and even the Destroyer.
Anyone using the KD’aii destoyer much, the first time i played against it I got my army eaten by it, since then I have managed to lead it around by the nose.
Ok my advice as a playing with CD but usually use other stuff in the UK tournament scene and ETC (I take it this is the same gerryb from the Warhammer Scottish Forums?)
With it being for SCGT, you need to think what is the �?onorm�?� at UK tournaments at the moment:
1: Ogres. And lots of them. Ogres are the largest % turning up at tournaments atm. Usually followed by WoC.
2: Undead. The new book with be at SCGT big time I feel. Expect to see some Black knight busses and mortis engines.
3: The �?otop 3�?� Lizardmen, Skaven and Darkelves.
With saying that, we can look at your army:
Sorceror-Prohpet… Lvl 4 / Mark of the Furnace / Hashut / 365pts
Atm I cannot comment on lore of Hashut, but I am going to test it a bit tonight. No dispel scroll? You also have nothing to draw out his dispel dice.
Infernal Castellan…BSB / Sh / Dragonhelm / Other Tricksters Shard /Talisman of Preservation / 207 pts
Is the dragon helm really worth it as you already have a ward vs fire.
Hobgoblin Khan…Sh / La / Dragonbane Gem / Wolf / 61pts
Im testing this also. Dragon bane gem could really mess someones day up for a 61pt model.
I like the 1st 3 core, fair enough. I am not sold on iron sworn, expecially since the command is soooo expensive (have you seen the FAQ?)
3 Bull Centaurs…AHW / 150pts
I think great weapons would be better. 2 x str 6 is better than 3 x str 4.
Magma Cannon…145pts
Magma Cannon…145pts
Deathshrieker…125pts ( Hellbound )
All fine enough. Hellcannon would be sexy�?�…
Total 2397pts
All in all its fine enough. I just think your wasting a lot of points on the Ironsworn. For the same points you could bump up the infernal guard a bit and buy some more war machines, like a hell cannon.
Hell Cannons with rerolls are sexy as hell!
Speaking of rerolls�?�I would buy a daemon smith for your magma cannons. If your dice go bad you could be wasting your main offensive weapon.
Other than that�?�I wouldn�?Tt be scared of this list really. Magma cannons are great, but range limited and can be taken down easily enough
If we think of the average ogre list, he will have 2 iron cannons. As long as he takes you cannons out he has nothing to fear from your army really.
Best thing to do is test the list. CD are still pretty new with limited numbers actually playing them (unlike Ogres and VC who have mass numbers to test stuff)
See what works for you and what is a bit �?omeh�?�
I am using my HE most likely for SCGT as I doubt I can paint an army in 6 weeks with preparing to move, so I could always lend you warmachines.
Sorceror-Prohpet....... Lvl 4 / Mark of the Furnace / Hashut / 365pts
at the moment I cannot comment on lore of Hashut, but I am going to test it a bit tonight. No dispel scroll? You also have nothing to draw out his dispel dice.
I find Flames of Azgorh usually draws out a dispel scroll first time :) Usually their eyes widen slightly when they read the spell description and they say, "scroll!!" before I even roll.
Enchanted Shield is definitely wise on the Lv4 though.
Infernal Castellan.......BSB / Sh / Dragonhelm / Other Tricksters Shard /Talisman of Preservation / 207 pts
Presumably its more for the armour save. I wouldn't take the Other Trickster's Shard as it means the IG/Ironsworn have to re-roll their parry saves. Not helpful.
Wouldn't dream of using Ironsworn at all in fact, far too many points.
Would combine the BCs into a single unit. I would actually go for fewer, larger units overall.
The whole of the Ironsworn unit have magical weapons…
Waphyrri… yes I am the same gerryb and after plaing against CD a bit more I don’t actually think they can compete at all in an SCGT environment.
Armies with fast chaff kill or at least tie up warmachines.
I think they could do with a proper cannon and the Inf can still die in droves to decent troops/magic
I agree thatCD will appear in increasing numbers at Tournaments while its the new bandwagon and people will like things like the Kdaai Destoyer with agood few claiming its broken ( which having played against it a few times is quite easy to handle with practice.
If i did run it I’d use 3 BCR in front to stop it getting blocked / diverted and another 3 BCR a little way behind to kill units getting down the side of it to stop it pivoting.
