I see no real problems with this list. In fact the BC is the very same one I use to great effect. Just the other day he took out a blorc regiment on his own (admitted I was very luck)
Well, its a badass evil name. How else do you describe CD?
The books are hilarious. Go R. Jordan!
Thanks, I wanted to make an all takers list that can hold its own. At the same time, I did not want to exceed 9 levels of magic or have more than 4-5 warmachines. Having too many warmachines is silly IMO. Thats why I despise fighting normal dwarves, they sit there and take 6+ warmachines and blast you. Thats why I like Cd, they actually fight.
The list is pretty balance and solid. You may want to drop the two small units of Warriors for a few Bull Centaurs to back the Hero up, but it’s nothing major.
As far as I remember he can be picked out. Not sure though. I usually use mine for running around the field taking on Skirmishers and War Machines. Works a treat.
he can’t be picked out because he’s not over US5, but unfortuaaly using RAW* you also no lobnger have a rank bonus, with the front 2 being bigger than the ones behind thanks to dwarfs having small bases
but, putting him in a unit of dwarves is like making an earthskaker then decideing you don’t want crewmen. pointless. the BC characters main advantage is speed, so why reduce him to M3, throw him in a unit of wolfboys or some BCs to use his movement, preferbly wolf boys since they can still reform around him.
Ah okay. But you are absolutely right. There is no pint in spending 154 pts on a model whose main strength is speed and then put him in with your warriors. Slam him in with your other BC I say.
