[Archive] 3rd ed whirlwind/ tenderizer in Tamurkhan list
scarlett fever:
Hey all,
been working at a CD list since just before the Tamurkhan list came out, however my primary reason for having a CD army is the 3rd Ed whirlwind and tenderizer models. Does anyone proxy these with the Tamurkhan list? I know I should just use a fan list but I’m just getting into Warhammer again after 15 years so need to have a modicum of acceptance in my gaming club before I really bring the whack on them, haven’t seen any fan lists there.
I’ve thought I could use them as K’daii fireborn with some canny basing (3 models as 6), they could fit this model, although the flaming attacks are a stretch. Any thoughts?
Base them on 50x75mm bases and just use them as Bull Centaurs?
scarlett fever:
true, guess i was thinking them of more ‘glass cannons’ but you’re right, that would be the closest fit by far.
DAGabriel:
I am still thinking of building them “normally” but build a second, bigger base where I can insert them both and use them as a skullcracker.
Vogon:
I’d go with the Skullcracker for the Tenderiser. It’s so clearly what the Warhammer Forge miniature is based on that it’d be a fool that wouldn’t let you use if as such.
Cheers
Vogon
French_noodle:
I thought to use them as Skullcracker too.
An other solution would be to use them as a Warriors of chaos Gorebeast Chariot on a chariot base. I can easily imagine these machine givings killing blows.
So yeah it is not in a tamurkhan dwarf only list, but could be easily used in a great host list, or even in an army based on two allied detachment.
scarlett fever:
Skullcracker would be nice, would give you options for a diorama style base. What’s the approx. footprint of a Skullcracker?
Vogon:
More or less 60x100mm, the same as an Iron Daemon.
Cheers
Vogon
My vote would for skull cracker as well.
Gunnerson:
My plan is to use mine as unit fillers for my Hobbos.
Honeym123:
Im using my as an iron deamon - it’s down right perfect og suits the oldschool chaos dwarf army perfect instead of buying an large modern model from FW
Bear in mind that the Whirlwind and Tenderiser models are significantly smaller than the Skullcracker and since it doesn’t have a base, you really should use something that’s about the right size.
Honeym123:
Well, you can find the base sizes around - just make one and throw it under?
Again, a Skullcracker doesn’t actually have a base. And, because of true line of sight, it ought to be reasonably similar in size. There’s a pretty significant differential.
The Skullcracker isn’t really intended to “be” a modernised Whirlwind/Tenderiser (like how the Dreadquake is an updated Earthshaker), it’s more that it uses some similar-looking components as a bit of a throwback to the 3rd Edition designs. Comparing a 7-Wound steam engine to a contraption pushed by a little boar centaur is probably a bit of a stretch!
Dont disagree on the scale thing its more to the point that if your going to use it as as such go with a full on 3rd edition retro army but the new list.
Soulassassin:
Valid point there Tommy H. My vote is on a Skullcracker still, just supply it with a magnifying glass :stuck_out_tongue_winking_eye:
Bolg:
Thommy H
If you have 3+ models, this would be my option.
just drop a instrument and a banner on the base and you have full command (:
Kyte:
I wouldn’t complain about using it as an Iron daemon with the Skullcracker option, as long as you made it clear when you presented the army. In a hardcore tournament, TLoS could be a problem, although as long as you’re lot being a douche and abuse the fact that it’s smaller than the original model to some great tactical extent, I’d personally never complain.
I use a greenstuff/plasticard replica of the 3rd Ed Juggernaut as my Iron Daemon as my Iron Daemon ans so far, all the comments I got have been positive.
