[Archive] 500 pts CD
Ogranoth blackhammer:
heres my first CD list:
chaos dwarf hero, armor of Gazrakh, great weapon
94 pts
Ogranoth blackhammer, captain of the “red raiders” is infamous for his abillity to command armies, no matter the size.
usual hero setup, used by charging ahead of his bodyguard and challenging to make a unit of troops fight a war of atttrition, allowing his warriors to come in the flank.
12 chaos dwarf warriors with blunderbusses
144 pts
the “red blizzards” are a unusually new addition to Ogranoth’s raiders. he hopes to test them and thier abillites soon.
never leave Zharr nagrrund wthout em. usual role of softening.
14 chaos dwarf warriors, musician, standard, champion, great weapons
193 pts
Ogranoth’s personal guard. when thier leader charges out into the fray, they move into thier usual combat tactic and smash into the flank.
used as hammer to Ogranoth’s 1 man anvil
25 hobgoblins
75 pts
bait.
total = 496 pts
Xander:
25 Hobbos is 50 points, unless you equipped them with something? :stuck_out_tongue:
Cool list.
Ubertechie:
As xander pointed out your hobgoblins are 50 points not 75 - but you could (if you can find 5 points from somewhere else) drop them down to 20 and add another unit of 20 - thus giving you 2 bait / flanker / distraction units that still get 3 ranks
Cheers
Ubertechie
Grotsnik:
Chaos Dwarf Sorcerer (general) - 65
Hobgoblin hero light armour shield wolf biting blade - 61
10 chaos dwarf warriors - 90
10 chaos dwarf blunderbusses - 120
10 hobgoblin wolfriders light armour shields - 130
hobgoblin bolt thrower - 30
total - 496
25 Hobbos is 50 points, unless you equipped them with something? :P
Cool list.
Xander
ah yes, my mistake while editing. i will edit in the correct cost.
Cheers
Ubertechie
Ubertechie
good point. i'll consider it.
total - 496
Grotsnik
why did you post this?
Grotsnik:
because i wanted peoples opinions of it
but its a thread for
Maul:
I would ditch the great weapons on the warrior freeing up 14 points, and take those 25 points from the hobgoblins giving you 39 points to work with. The great weapons are expensive and they take your armor down a lot. In combat the chaos warriors job is just not to die and throw in a lot of static combat resolution. Let your lord do the wounds.
things you might do with those points:
1. Buy a bolthrower and 4 more hobgoblins
2. Bump your blunderbuss unit to 15 and get a hobgoblin for your unit
3. Take one hobgoblin from your existing unit and make two additional units of 10 hobgoblins each (somebody has to claim the board corners and there is no cheaper way to do it)
4. Buy your unit of chaos dwarf warriors a war banner, your blunderbusses a musician, and two more hobgoblins
Grotsnik:
I think you definately need some sort of magic in there when im creating lists i always try to think of the possible things that other people could have in the same level lists and then have something in my ary that would probably match or beat as many things as possible
eg in a 500pt list most people wont have a level 2 sorcerer so i probably dont need one
