Is there any specific base size for the Hell Cannon?
furrie:
It doesn’t come with a base, but I could check on what base it would fit when I’m home
Nope, no base. I think there is provisionin the rules for monsters without bases, but I could be wrong. It fits quite nicely on a 100x80mm regiment base anyway.
I measured it at 80mm square a while back
Ok, Im planing to build my own thats why I ask. Haven’t played the 8th ed yet, or much at all for the last few years. Would there be any problems if the base got too big? My idea might be hard to fit on a chariot base, if that is 80x100.
burock:
Ok, Im planing to build my own thats why I ask. Haven't played the 8th ed yet, or much at all for the last few years. Would there be any problems if the base got too big? My idea might be hard to fit on a chariot base, if that is 80x100.Avian has info on that straight from GW. it is 80x100 mm.
tjub
furrie:
Ok, Im planing to build my own thats why I ask. Haven't played the 8th ed yet, or much at all for the last few years. Would there be any problems if the base got too big? My idea might be hard to fit on a chariot base, if that is 80x100.A chariot base is 50X100 mm
tjub
Ah, okay… Thanks!
Uh, don't know if Im just stupid, or did you mean 60x100? But can't find the right base...Ok, Im planing to build my own thats why I ask. Haven't played the 8th ed yet, or much at all for the last few years. Would there be any problems if the base got too big? My idea might be hard to fit on a chariot base, if that is 80x100.Avian has info on that straight from GW. it is 80x100 mm.
tjub
burock
Bassman:
Ok, Im planing to build my own thats why I ask. Haven't played the 8th ed yet, or much at all for the last few years. Would there be any problems if the base got too big? My idea might be hard to fit on a chariot base, if that is 80x100.Do you rulewise? I do not think it's a problem as a larger base is normally a disadvantage.
tjub
It’s the standard movement tray size - big enough for a 4 x 5 unit of 20mm based models. So you could either cut it out of the modular kit or find an old GW movement tray and fill it in a bit (which is what I did for my Hellcannon).
burock:
you can modify a movement tray as Thommy H suggested or build one. 3mm thick balsa would do the trick or example.Uh, don't know if Im just stupid, or did you mean 60x100? But can't find the right base...Ok, Im planing to build my own thats why I ask. Haven't played the 8th ed yet, or much at all for the last few years. Would there be any problems if the base got too big? My idea might be hard to fit on a chariot base, if that is 80x100.Avian has info on that straight from GW. it is 80x100 mm.
tjub
burock
http://www.games-workshop.com/gws/catalog/armySubUnitCats.jsp?catId=cat470008a&rootCatGameStyle=
tjub
Two layers of card work well, and are easy to cut. Having two layers glued together makes it unlikely to warp.
ryanamandaanna:
I ended up gluing together 4 40mm bases to make it 80mm square…
Castellan:
You could put it on a base, but the set doesn’t come with it. Just a question: why would you want to put in on a base?
-Castellan
ryanamandaanna:
it helps to know frontage for things such as how many enemy models can attack you, etc, etc.
Plus it looks nicer.
Nicodemus:
Plus it looks nicer.Yeup!! For me this is pretty much the only reason, personally, that I'd put the effort into making one. Size for attacking units is a bonus I guess, but wouldn't be my first thought when considering such an undertaking.
Thommy H
You could put it on a base, but the set doesn't come with it. Just a question: why would you want to put in on a base?The reason for the base in my case is because the conversion would need it and IMO it looks better as well. :)
-Castellan
Castellan
