Tarrakk Blackhand:
Here’s my WIP progress for Blunderbuss Unit #2. These are the BFSP Thunderers Kera sent me last year. Although the 7 gun touting warriors couldn’t be changed too much from those of Unit #1, I was able to change two of the three command group.
These 3 Battle For Skull Pass Thunderers are being converted into Chaos Dwarf Blunderbuss Command Unit #2.
I wanted to make them look different from Unit #1, so I changed the pose of the Champion as well as the musical instrument of the Musician. Sadly, not too much can be done for the Standard Bearer.
All these models are photographed before I add Green Stuff to change their armour.
The Unit Champion. Note the new arms. They are a combination of four different arms.
The pointed finger comes from the Dwarf Miners Set, the arm attaching that hand was originally open and was from the Dwarf Thunderers set.
The hand holding the gun came from the Thunderers set while the arm was from the Warriors set and was holding a hammer.
Same group from the back.
Here we see the Musicians. The Musician for Unit #2 has been changed to play the drum from the Dwarf Thunderers set.
His original horn was chopped up and filed down so that the drum could fit there. This left a strange location for his hands. Luckily, they weren’t too far away from the drum to make logical sense.
The Musicians from the back.
