Nicodemus:
Edit: This post was recovered after a website restore deleted content from ~11pm Jun 14 to 3am Jun 15, 2019. Here’s the missing post from Zanthrax, then mine:
This is certainly an odd design choice. I wonder if they just had problem with the model with the rivets on the hat because the axe in that model is closer to the body… Hmm, nah, never mind. They have other models with tight crevasses like that which don’t cause enough of a problem with the moulds for them to make modifications. Maybe one was an early version that was mostly used in the studio early-on and the other is a later update?? Sheesh. Who knows. There’s a chance Alan Perry might know if he was the one that did the modifications.
So, can you believe - out of 27 4th edition Bull Centaurs (27… 27!!!), I only have one of these guys!?!? I can’t believe it. It’s probably not a coincidence though, as I don’t care for the flaccid hat look :hat off Anyway, out of 27 (27!!) I have the guy with the rivets on the weapon, not rivets on the hat.
Looking through some of my older material I found these from 1994 and 1995:
In the 1994 White Dwarf Presents: Chaos Dwarfs supplement they have this catalogue page (upper right) with the Upper torso with axe 3 showing rivets on the hat. Inside the painted models also show the same version with a clearly highlighted rivet on the hat and no highlighted rivet on the weapon.
In the 1995 White Dwarf issue 186, they show the exact same Chaos Dwarf army in a battle (I guess the studio wasn’t shelling out for multiple painted versions!) but at the back in the catalogue section they show the model with the rivets on the weapon and not on the hat, although here it’s clear this is a showcase of individual models that you purchase in a blister pack and not individual part numbers that you’d use for ordering.
So I wonder if these two had the same part number or if they had different part numbers for mail order? In case it’s not clear in the image (it’s not clear to me) here’s what I have from the White Dwarf Presents: Chaos Dwarfs supplement catalogue entry, which has a suspicious gap:
Bull Centaur Bull Body Left Side 1… 75815/1
Bull Centaur Bull Body Right Side 1… 75815/2
Bull Centaur Upper Torso with Axe 1 75815/3
Bull Centaur Upper Torso with Axe 2 75815/4
Bull Centaur Bull Body Left Side 2… 75815/5
Bull Centaur Bull Body Right Side 2… 75815/6
… no catalogue entry… 75815/7
Bull Centaur Upper Torso with Axe 3 75815/8 (rivets on hat shown)
Bull Centaur Upper Torso with Axe 4 75815/9
Bull Centaur Upper Torso with Axe 5 75815/10
Bull Centaur Upper Torso with Axe 6 75815/11
Bull Centaur Standard Bearer… 75816/7
I believe the
8582 catalogue number shown for the Bull Centaur models from the White Dwarf issue above is the code for the blister packs of Bull Centaurs, which contained a single random model.
I looked through the rest of the catalogue. It’s clear that 75815/75816 are the Bull Centaur codes. The White Dwarf Presents: Chaos Dwarfs supplement catalogue entries are the same as those in the
1993 Black Catalogue entry for
Bull Centaurs.
Just to be clear, The Black Catalogue was released in 1994, same year as the Chaos Dwarf Supplement, but listed all the models released in 1993.
The missing 1993/1994 catalogue entry for part “75815/7”, right before the suspect torso, seems to be a red herring though.
The Stuff of Legends archive doesn’t have an entry for Bull Centaurs in with the Chaos Dwarfs from the “1994 catalogue” (released in 1995 and covering all models available in 1994), but in the 1995/1996 Annual the
Bull Centaurs are listed again with part numbers unchanged and using the same stock images. It’s not the same scanned page though, it’s the real page from the proper issue! The
1997 catalogue has the same part numbers.
Then in the
1998 Annual catalogue the part numbers all changed and we see the updated
Upper Torso with Axe 3 with the rivets on the weapon (part number 021100508).
Bull Centaur Bull Body Left Side 1… 021100501
Bull Centaur Bull Body Right Side 1… 021100502
Bull Centaur Upper Torso with Axe 1 021100503
Bull Centaur Upper Torso with Axe 2 021100504
Bull Centaur Bull Body Left Side 2… 021100505
Bull Centaur Bull Body Right Side 2… 021100506
… no catalogue entry… 021100507
(WFT??!??)
Bull Centaur Upper Torso with Axe 3 021100508 (rivets on weapon shown)
Bull Centaur Upper Torso with Axe 4 021100509
Bull Centaur Upper Torso with Axe 5 0211005010
discontinued?
Bull Centaur Standard Bearer… 021100607
You can translate old part numbers to the new ones like this:
__75815/8
______508
021100508
It seems like 1998 was the last time models for the Chaos Dwarf army were officially listed in catalogues.
So that BC model seems to have had two versions since close to the beginning as both versions showed up early (White Dwarf Presents and WD issue 186). So very strange! So I wonder what would have happened when ordering the specific part number, might it just have been random which one you got or is it that maybe the rivets on the hat was an earlier era and the rivets on the weapon came soon after, but the catalogues were just slow to update their stock image??
Edit - I’m reposting this, SO GLAD I SAVED THIS POST!! Webserver issues overnight and we lost all posts and uploads from last evening.
