[Archive] bloodletters to fireborn?
ClawLeader:
So I got 10 bloodletters laying around as stand in black orcs from RH. Now would it be too unreadable to slap them on 40mm bases, cut out the swords and cover them in fire and metal plates?
Grimbold Blackhammer:
Should be fine/readable so long as you identify them when you deploy them. I use skinny little models on 40mm bases for my Fireborn too and the extra real estate gave me some fun modeling opportunities with the bases!
ClawLeader:
Well my phones autocorrect has once again struck again. Unreasonable was the word. My thoughts were to cut the sword hand off and make it a burning stump and maybe separate the limbs and have them connected by flame? Just trying to get.use out of them.
Groznit Goregut:
Doesn’t quite look like a machine powered by a fire demon, but then again, neither do the official models…
ClawLeader:
Fluff says they’re bound fire daemons in a host form of metal, so really they could be a lot of things so long as the other player is clearly informed of what it is
zhatan87:
Right.
I've both two models, and fireborn are pretty high in comparison to bloodletters... You should up them on their bases to make them enough high:)
And as fireborn are pretty thin, bloodletters would be ok.
Skink:
ClawLeader
It has been done! Here:
http://www.chaos-dwarfs.com/forum/attachment.php?aid=2861
I'd leave the sword if I were you. Just scrap the rune of Khorne on the hilt. if you want to cover the model in flames concentrate on the blade and the "fins" on forearms and back. that would look amazing :). Lastly, you can sculpt a helmet with a beard if you feel brave.
Bolg:
Go for it! And yes leave the swords.
Yes definitely try it, but turn some of the ends of the arms into weapons, maybe using pieces of the swords, instead of all of them having hands
Hmmm, maybe I should try this as well. Looks better than I would have thought, and I got stuck with only three of them last try. Too boring to finish the last…
To my mind they’re far too small to be Fireborn. Your opponent would need to okay it in advance as it’s enough difference to mess with LoS considerably.
Goltor Lintrepide:
If you’re any good of a sculptor maybe you could try to add some flames to the model and put some spare bitz of armor if you have any so it looks more mechanic-ish.
As for the link you post Skink, the only thing i’m seeing there is an ordinary bloodletter on a 40mm base. Not convincing at all. But with some work on it, I admit the model could make a great fireborn.:stuck_out_tongue_winking_eye:
