WoodenPickles:
Okay in 40k they have all sorts of bound daemon things like: defilers, brass scorpions, soul grinders, towers of skulls, lords of battle, and many more. What would be the differences if theses things were moved to fantasy to be used by Chaos Dwarfs. How would there rules be different.
Like for the defiler you could take away the gun bits exept the center one and give it a nother set of front arms for the additional close combat weapons.
m ws bs s t w i a ld
7 3 3 6 4 3 3 5 3 Armor save of 4 plus
The battle cannon could be replaced with a stone thrower like gun that has a strenth of 8 under pie plate and it could have berserk rules like the hellcannon, but roll a d6 every turn on a roll of a one it does that for the rest of the game. give it the option with two close combat weapons instead of the guns and add in a 5plus ward and unbreakable fear causer for like 200-250 points.
I was seriously considering making a chaos dwarf warmachine with the defiler or brass scorpion. As for rules, unfortunately you can’t just take the stats, and especially can’t take the points value, from the 40k equivalent… 40k point values are about half of what they would be in fantasy (see daemons of chaos comparisons), and the stats aren’t the same as they would be at all either… I’d like to help in the creation of some rules for chaos dwarfs using a more simplified version of the brass scorpion or defiler… If not, i’ll just model a hellcannon onto some spidery defiler legs like i’ve seen others do
