tommy125347:
Hello everyone :hat off
I’ve decided to explain how i convert my chaos dwarfs outta bfsp goblins and give them a distinctly mongolian theme…
Here it goes…
What you will need for the warriors:
Bfsp goblin spearmen, any will do!
loads of green stuff
a few extra weapons (i like marauder weapons my self)
goblin wolfrider head
(the one with the mongolian hat)(i cast this one because i use alot)
Step 1.
Cut off hood up too eyes of goblin. Cut off spear bottem(if able) and top.
Step 2.
Cut the hat of the wolfrider head. Place it on the new dwarf.
Step 3.
file off moom symbol on shield or put a bit of greenstuff over it.
Step 4.
put axe head, sword, mace ect where spear top used to be
Step 5.
Roll a ball of green stuff and stick it to his thin belly. smear it until it looks about right and voila a fat stomach!
Step 6.
roll up a couple thin sausages of green stuff(i usually make 3 or 4), and indent little lines on them (as usual :P)
Step 7.
Make a small mustash out of green stuff!
Step 8.
Put the sasauges just over his chin in a line.
Step 9.
Put mustash right under nose.
Step 10. (the tricky part!)
He needs him some armour…
Make five rectangles out of greenstuff…
put three indented lines across each of them…
Also put a small hole on the end of each…
(think bamboo samurai armour :D)
Step 11.
Put 2 of the rectangles on each of his shoulders
Step 12.
Put 2 of the rectangles covering each thigh
Step 13.
Finally put the last one covering his but!
I will put one up for my blunderbusses too
Also pictures of this process will be up this evening when i am home
