centauro enano:
I have a unit of chaos warriors dwarves original. But as you know, they are too big and impossible to put them straight.
I have been thinking, and the only thing I can think of is to cut the axes and put them in another direction, but I do feel sorry for :(.
Any suggestions?
apocalypstia:
the original big hat chaos dwarfs warriors? or something else? by straight do you mean squaring the shoulders to be parallel with the base front?
Ancre:
Put them on bigger bases (orc-size for example) ?
Pyro Stick:
They rank up fine if they are on diagonal bases.
Mine are all diagonal, but I have seen some that alternate putting them on the front of the base and the back.
centauro enano:
Thanks for the help :hat off.
apocalypstia
Yes, parallel with the base fron
The bases of orcs would be perfect, but regulations are not for them :(, and with bases remain tilted in a rare position.
I will continue thinking
you could also mount them on different levels… like standing on lava rocks and some not on the lava rock might help
Bassman:
I faced your prblem with my first unit of dwarf warriors. I do not like ALL of them on diagonal bases, they really look weirdo, like they are not facing enemies… and this is not very dwarfish: we always watch enemies’ eyes!
You can alternate diagonal and straight bases ad use my mini-tutorial:
https://discourse.chaos-dwarfs.com/t/10966
you gave me the idea to dust it from the bottom of my old folders :hat off
Hope it could help to rank your warriors. :cheers
centauro enano:
I faced your prblem with my first unit of dwarf warriors. I do not like ALL of them on diagonal bases, they really look weirdo, like they are not facing enemies... and this is not very dwarfish: we always watch enemies' eyes! :|
Bassman
Thank you for the help Bassman :cheers.
I feel sorry for cutting ax. I have to and not cut or cut dilemma
Kera and
cornixt Good ideas :hat off
Bassman:
Be brave! Cut axes, it’s not really a problem to glue them back. Afterall you’re just making a straight cut. Nothing more complicated.
Remember, no pain, no gain
i also would like to say is pin it!! so that it will last a long time
