Has anyone tried making an army out of them? Very basic troops, if a bit large, I may have trouble putting them on 20mm bases. Have enough for a couple of big units, mainly of melee troops though. Plus the centaur type figs.
If I go this route though, I’ll have to figure out how to make up some twisted machines though, plus bigger monsters and monstrous cavalry.
Has anyone tried this before? Did a search using “Confrontation” and didn’t see it specifically…
I think a blend of figures will do the trick, that’s the true spirit of Chaos, not a single figure alike. I like the way he went around the hobgoblin route using massed Night Gobbos, easier that way.
Darn that was a LOT of figures from many manufacturers!!!
Love it!
Ditto on the idea of ranking them up like the Mantic figs, let’s truck on forwards and kick butt!!!
I have quite a few of these that I am planning to use in my army as Abyssal Dwarf berzerkers amongst other things. If when I finally get the time to lay paint on them. The caveat is that I play Kings of War and not WHFB. The core unit size is standardized as a blog, so individual base size doesn’t matter. With models that don’t fit the standard 20mm bases, I use 25mm bases and rank them in 3 rows of 4 models 25mm square with a 5mm unit fill line at the back. This makes it the same size base size as a 20mm 4 rows of 5 models each unit and allows for the models to fit the bases confortably. Not a suitable fix for WHFB unless you never play tourneys and your normal opponents are not particular.
