I’m intrested in converting hobgoblins and Im going to buy the goblin regiment box-set. Does anyone have any idea if the goblin box-set allows the goblins to be armed with hand weapons and shields. I’ve had a look at the spures and It looks as if its only possible to arm them with bows or spears and shields…
I create my Hobgoblins out of goblin heads and shields and Brettonian bodies. But well, the method isn’t for everyone and requires you to order lots of bits. Although my method is on here, I am a rather crappy painter so it just… doesnt’ convey well. It also, as it has been fairly pointed out, creates Hobgobala Khan style footmen and archers to go with your Oglah Khan style wolfboyz rather than the more primitive tribe of Hobgoblins used by 5th edition Chaos Dwarves.
To make them out of just Goblins is terribly problematic. You may as well be trying to create human models out of halflings. You need a human sized body and the only way you can get those is from Bret or Empire footmen (Brets can be painted up to look to have Chinese-derived style clothing that everyone wore in the East while Empire footmen give you more of a western look).
I create my Hobgoblins out of goblin heads and shields and Brettonian bodies. But well, the method isn't for everyone and requires you to order lots of bits. Although my method is on here, I am a rather crappy painter so it just... doesnt' convey well. It also, as it has been fairly pointed out, creates Hobgobala Khan style footmen and archers to go with your Oglah Khan style wolfboyz rather than the more primitive tribe of Hobgoblins used by 5th edition Chaos Dwarves.
Hobgoblyn
So to convery hobgoblins Id need to use the Bretonnian men at arms models without the heads and sheilds...Id replace them with goblin heads and shields?
